Topic: Simple multi-track player (Read 2755 times) previous topic - next topic
  • chrisjj
Can you recommend a simple WMA+FLAC+MP3 player for Windows that will let me:
1) drop up to four tracks into it
2) start play of the first track
3) on a single keypress seamlessly switch play to any other track at the same time position.
This is for audio comparison listening tests. Thanks.
  • Last Edit: 05 July, 2012, 09:06:00 AM by chrisjj
  • Apesbrain
foobar2000 with ABX component can do exactly what you want with TWO tracks.  Not sure why for "audio comparison listening tests" you'd want to have more than two things being compared at any given time.  If this is a test of encoders, one of the things being compared should be the source.
In any case, Audacity could do it with four tracks playing together or individually in any combination.
  • chrisjj
Thanks. It fails on "seamless" here, usually issuing a click upon switch.
Easier to sort more in order.
No - test of programme material.
It fails to meet the requirement for switch on single keypress, AFAICT.
  • Last Edit: 05 July, 2012, 10:07:46 AM by chrisjj
Download the free trial versions of DAW software.
Ableton Live or Traktor come to mind.
  • chrisjj
Thanks. If anyone can confirm they do what's asked, I'll try them.
  • eahm
REAPER, FL Studio, Adobe Audition are worth the test as well but really any audio editor should do what you need:
http://en.wikipedia.org/wiki/Comparison_of...l_audio_editors
  • chrisjj
Thanks, but I see nothing there to suggest any audio editor will, and none of those that I have tried do.
  • trout
Might the ''Solo'' buttons, found at the left of each track, fit your requirement for track switching?
Seems to me it should work, unless I've misunderstood what you need.
~ Sorry for my bad english.
  • chrisjj
Can't see how. I find no keys to solo respective tracks.
  • romor
That player could be "simple" if it only provides this exact feature, as what you are looking for is application which would allow reading two consequent files from playlist in memory (relative to currently playing tracks) and provide programmable seek timer. I don't know of a such, and I guess you'll need to hire programmer if you need this exact feature
If your seek points can be fixed, you could write cuesheet and get seamless output from foobar
If seek points are arbitrary, then at best again with foobar you could use comserver component, which I tried now out of curiosity with this results on XP:
1. ASIO output (regardless playback output buffer) produces gap or 34ms
2. Kernel streaming with playback buffer of 50ms, produces ~ 21ms gap
3. DS has a biggest gap, but you could use some fader DSP component to make transition almost seamlees (not builtin fader which is tied to playback buffer and always produces gap)
If you are interested in this adventure, replay and I tell you simple details
  • chrisjj
Well, foobar2000 with ABX has this feature. Just that it doesn't work with full quality.
results on XP:
Ah. Seems the task is trickier than one would think.
Thanks for the info.
  • Last Edit: 06 July, 2012, 09:02:10 AM by chrisjj
  • db1989
  • Global Moderator
Well, foobar2000 with ABX has this feature. Just that it doesn't work will full quality.
In case anyone’s about to scream TOS #8  I presume this actually refers to this earlier post:
  • chrisjj
It does.
