Topic: How to obtain an offset-corrected rip using cdda2wav? (Read 2319 times) previous topic - next topic
  • Dario
Hello there,
I have been going through the cdda2wav man page, and noticed that the -offset command takes sectors as an argument (starts offset sectors behind […]), not samples (like all the other CD-ripping software I’ve encountered).
So, the question is—if I know that my drive’s reading offset is 6 samples, how do I convert that to sectors (is it even possible?) and pass it to cdda2wav in order to obtain a rip that is offset-corrected?
Thank you.
  • Last Edit: 04 July, 2012, 05:51:37 PM by Dario
  • Jan S.
As there are 588 samples per sector it is probably useless for offset correction...?
  • skamp
Use cdparanoia -O I guess.
See my profile for measurements, tools and recommendations.
  • Dario
But I’m willing to use cdda2wav, not cdparanoia.
That’s what I was afraid of.
EDIT: What do you guys recommend for ripping on GNU/Linux, anyway? I figured that the cdrtools package would be perfect, until I ran across this issue with cdda2wav.
  • Last Edit: 05 July, 2012, 09:48:03 AM by Dario
  • skamp
Rubyripper, which makes use of cdparanoia.
