Topic: Help me set up the best way to rip and tag FLAC with EAC 1.0 beta 3 (Read 7360 times) previous topic - next topic
  • greynol
  • Global Moderator
The CD-TEXT data in the cue sheet is normally filled in with data from sources other than the CD anyway.
My point exactly!  Of my discs, only a small fraction contain cd-text.
Preserving CD-TEXT isn't even a compelling reason to generate a cue sheet
The same can be said for just about everything stored in a CUE sheet for most discs* but don't tell that to the anal-retentive types.
(*) Pre-emphasis and HTOA are the only notable exceptions, AFAIC, though I have a few discs with interesting index information; maybe more if I had some classical titles(?).
  • Last Edit: 10 July, 2012, 02:44:44 AM by greynol
