Topic: I’m having problems with my songs not showing any metadata/tags (Read 1135 times) previous topic - next topic
I'm having problems with my song track not auto filling the information, I'm sorry I would do a search but I'm not sure how to term the problem, thanks for any help
foobar2000 is not showing any metadata for your tracks because you did not write any metadata to them when you created them.
It was you who created them, right?
LOL db1989, he must have used a bad program to "rip" those tracks.
Since your tracks don't have tags, you can use foobar to guess them from the filename. It's not always 100% foolproof since you might have some inconsistency in your file naming scheme, so it may require some editing afterwards, but generally it's a lot easier than doing them all manually.
Right click the tracks and select "Tagging" - "Manage scripts". Then under "Actions to perform" select "Guess values from filenames". From the look of your playlist it looks like the pattern %track%.%artist%-%title% will work for most of your tracks.
