Topic: Sort by Folder & Track number not working in Library Viewer Select (Read 1275 times) previous topic - next topic
  • Alangar
Hi all,
I am new guy to this forum, i use foobar 2000 version v1.1.13.
I use facets and Libary viewer as shown in the screen shot, the problem i face is that songs are not sorted in the library viewer as per folder (directory) and track number. (Sort by folder works, but i further need to sort by track number which is not happening)
The default was %path_sort%.  I even tried: %path_sort%%tracknumber% but didnt work.
Pls see the screenshot:
https://docs.google.com/file/d/0BwhShAWiWN0...UUwclRhcHM/edit
Pls help me, Thanks,
Alan
  • Last Edit: 02 July, 2012, 10:59:12 PM by Alangar
  • kode54
You'll have to use:
$directory_path(%path%) %tracknumber% %title%
  • Alangar
You'll have to use:
Thank you very much admin, also i wish to sort by folder, disc number, track number.
I tried this, i this correct ?    $directory_path(%path%) %discnumber% %tracknumber% %title%
Can you pls share some help web link related to this, which will help me.
Thank you again,
Alan
  • Last Edit: 02 July, 2012, 11:20:48 PM by Alangar
