Topic: can faad2 support multiple aac decoder instance (Read 2814 times) previous topic - next topic
  • vindows
Can faad2 support multiple aac decoder  instance? (That means if I can create multiple decoder and decode several files simultaneously)
Can faac support multiple aac encoder  instance?
  • saratoga
Generally, I don't think decoders support any particular number of instances.  Rather, the operating system and hardware they are run on typically determines that.
  • skamp
  • Developer
I'm not sure I understand the question. Yes, you can launch multiple instances of faad/faac at once, manually, via a script, or whatever.
  • lvqcl
  • Developer
Maybe the question is about thread safety of faac and faad2 DLLs?
  • Garf
  • Developer (Donating)
As far as I remember FAAD2 at least requires you to allocate all its working memory in a structure and pass it into every function, so it's likely to be thread-safe.
