Topic: Addressing right click playlist functions from the commandline (Read 991 times) previous topic - next topic
hope someone can help with a commandline query...
I'm trying to load a few tracks into a playlist and then convert them but I can't get the switch to work.
So far:
foobar2000.exe "C:\Test Recording2.mp3" "C:\Test Recording.flac"
Will load the two clips into a playlist and start playing.
But how can I address the Convert to > a saved preset called "WAVtest"?
Going by the wiki page:
  /command:<menu command> - invokes the specified main menu command
  /playlist_command:<context menu command> - invokes the specified context menu command on current playlist selection
  /playing_command:<context menu command> - invokes the specified context menu command on currently played track
  /context_command:<context menu command> <files> - invokes the specified context menu command on the specified files
foobar2000.exe /context_command:WAVTest "C:\Test Recording2.mp3" "C:\Test Recording.flac"
Doesn't work.
Also is it possible to run the command Replaygain > Scan per-file track gain via the commandline?
Thanks in advance
  • Last Edit: 28 June, 2012, 03:39:20 PM by trilliansounds
Found this topic on addressing volume controls from the command line.
[a href='index.php?showtopic=94883']Volume control command line[/a]
So foobar2000.exe "/command:Up" will increase the volume
But none of these variations work:
foobar2000.exe "/command:WAVtest" "C:\Test Recording2.mp3" "C:\Test Recording.flac"
foobar2000.exe "/context_command:WAVtest" "C:\Test Recording2.mp3" "C:\Test Recording.flac"
foobar2000.exe "/playlist_command:WAVtest" "C:\Test Recording2.mp3" "C:\Test Recording.flac"
foobar2000.exe "C:\Test Recording2.mp3" "C:\Test Recording.flac" "/playlist_command:WAVtest"
What's missing?!
  • foosion
  • Moderator
You could try the foo_runcmd component. With it you can launch foobar2000 with the following command line:
foobar2000.exe "/runcmd-files=<pattern>" <files>
Replace <files> with the list of files you want to convert and <pattern> with a pattern for your converter preset. "Convert/WAVtest" might work. You can use the "Run Command" GUI to test the pattern.
http://foosion.foobar2000.org/ - my components for foobar2000
