Topic: Is there a limit of 5 UI in foobar v1.1.13 ? (Read 1363 times) previous topic - next topic
  • Alangar
I am a newbie and very much in to using Foobar v1.1.13 (I think the latest version)
Is there a limit of 5 UI in foobar v1.1.13 ???
I have added
Facets
Libary viewer
Album art 1
Album art 2
Visualisations.
The problem i face is, i am not able to add more UI. I can only replace the existing UI ? Cant i design the UI Area as i wish ?
So is there a limit in adding UI ? I need to add two or more UI...
Also i wanted more themes, i am not getting proper web sites links. Pls pls help me ...
Alangar M
  • Last Edit: 27 June, 2012, 02:28:37 PM by Alangar
  • Andreasvb
Just replace something with a Splitter.
  • Alangar
Thanks dude...
Also, one quick question....
In the facets, i have added a new column named "Mood", but when i select a particular mood, the other columns in the Facets do not filter / arrange according to the option i select.
The columns like genre, album just stays static and not dynamic.
Pls help me, what change or tweak should i make ?
Alangar M
Can it be that the mood-facet is the last pane in your layout? What happens if you click a genre?
More information would be helpful - for you and potebtial helpers!
  • Last Edit: 27 June, 2012, 04:32:02 PM by q-stankovic
german support forum: www.foobar-users.de / user: qwert73
  • Alangar
Thanks a ton, i moved the mood pane to first and the problem solved...
Thank you so much for your support !!!
Alan
