Topic: XLD: still using VBR-NEW (Read 1288 times) previous topic - next topic
  • Antigen
I have noted that XLD is still using --VBR-NEW
But actually --VBR-NEW Vn    is not the same of using only    -Vn  ? (where n is a number)
Or they are different preset?
  • db1989
  • Global Moderator
LAME 3.98 beta 1  May 16 2007
Robert Hegemann:
The newer VBR code is now LAME's default VBR routine
So, if you do not specify a VBR mode, LAME uses VBR-new. In other words, the two settings you asked about are the same.
  • Antigen
Ok, this is important
