Topic: Track name issue (DarkOne v3.0) [moderation: issue= composer in title] (Read 1142 times) previous topic - next topic
My issue is as the picture shows below--simply put, composer names seem to show up before the title of the song. It's a pretty large nuisance to the otherwise very enjoyable music player. I've tried renaming the files, deleting the composer and more but to no success. I also couldn't find someone with a similar issue via google or this forum; though, I likely wasn't using the correct keywords. Hopefully you guys can help me out here...
DarkOne v3.0 uses Columns UI if that's any help... Looking through the preferences, I couldn't find a solution to my situation. If asked, I'll try and provide more information.
  • Last Edit: 20 June, 2012, 08:27:44 AM by tots_o_tater
  • marc2003
right click the "title" columns header. under "column details", on the script tab, select the display tab and simply enter
%title%
%title%
Thanks a ton, man. It worked like a charm.
