Topic: FLAC WILL NOT CONVERT... (Read 777 times) previous topic - next topic
  • maniacal
Just wondering if anyone would have an idea why..or what is the difference between these files? i am using Total Video Converter 3.14. it will convert/open (to a WAV or MP3 file for the walkmen to play) the FLAC file with the sample rate of 44100 Hz..but not the one with a sample size of 96000 Hz. Both formats "play" in FOOBAR. i apologize for asking here. its not a FOO problem. i could not find anything "googled" on it.
DOES CONVERT
Duration : 3:01.373 (7 998 564 samples)
Sample rate : 44100 Hz
Channels : 2
Bits per sample : 16
Bitrate : 783 kbps
Codec : FLAC
Encoding : lossless
Tool : reference libFLAC 1.1.2 20050205
Embedded cuesheet : no
Audio MD5 : C1E16A4DDC66E31EEDF0D7672842094A
WILL NOT CONVERT: BELOW
Duration : 2:45.884 (15 924 874 samples)
Sample rate : 96000 Hz
Channels : 2
Bits per sample : 24
Bitrate : 2740 kbps
Codec : FLAC
Encoding : lossless
Tool : reference libFLAC 1.2.1 20070917
Audio MD5 :
  • maniacal
sorry. it was a dumb question. i converted using the foos own component converter. duh! still getting used to how powerful this app has become. not sure why i even tried the other converter app.
  • db1989
  • Global Moderator
Binned, also get your keyboard fixed.
