Topic: Is it possible to verify individual FLACs against accuraterip database (Read 3095 times) previous topic - next topic
  • kidnukey
Is there any way to verify individual FLAC files against the accuraterip database?
  • Last Edit: 15 June, 2012, 11:08:46 PM by kidnukey
I've been able to do this *sometimes* with XLD on the Macintosh (Open Folder as Disc.) I've never tried it on EAC, dBpowerAMP, or CUETools on my PC.
The Loudness War is over. Now it's a hopeless occupation.
I  can only check a whole cd using the component "File Integrity Verifier" for foobar.
  • Porcus
A single track? Theoretically possible, but you don't want to do the job ...
Yes. Cue Tools will do it.
http://www.cuetools.net/wiki/CUETools_Download
Simply navigate to the folder the files are in, tick the 'Verify' option and hit 'Go'. Then watch as it does it's magic.
  • Dario
But you need to have the whole album inside that folder, along with the correct tags. I don’t think that’s what the OP is asking for.
  • db1989
  • Global Moderator
For posterity:
AccurateRip library Checker: Batch check your Lossless Rips Against AccurateRip
Coming Soon: Check Individual Tracks (currently PerfectTUNES AccurateRip can check complete albums, tagged or not)
  • spoon
  • Administrator
For posterity MKII, details of why it is difficult to check a single track:
First off AccurateRip identifies albums by the whole CD TOC, a single track is missing that information, but it is not the end, if you have a track number you will be able to work out the TOC (we have been building a huge database of every CD to allow this kind of lookup).
Secondly, often single tracks are ripped with a non referenced offset, or even the disc it was ripped from might be a different pressing than that in AccurateRip, either way you will need 5 sectors from the track before, or the track after - we are currently collecting that information for use.
  • db1989
  • Global Moderator
Thanks for the information, spoon.
