Topic: foobar2000 cannot read tags in all WAV files (JRMC can) (Read 2432 times) previous topic - next topic
  • liverbird
Dear Support,
I encounter a strange problem that tags of some files can be read by foobar but some can't.  All tags in the wave files are created by a tag editor "Tag & Rename 3.6" and all of them can be read by JRiver Media Center.  I have no clue on the problem, is that something wrong with my way of editing the file? Or I can upload the problem file to Support Team to see what goes wrong.
Thanks for your kind help in advance.
Regards,
John
  • kode54
  • Administrator
Yes, uploading a non-working file would be helpful in diagnosing the problem. Or, if you can reproduce the steps necessary to tag such a file, given any particular untagged file, would also be useful.
  • db1989
  • Global Moderator
If uploading copyrighted material, please follow #9 of the terms of service by limiting your file to a sample with a maximal duration of 30 seconds.
  • liverbird
Thanks for the reply.  The steps are simple, use EAC ver 1.0 beta 1 to rip "Candle in the Wind" of Elton John, then use Tag & Rename ver 3.6 to add fields and cover art to the wave files, Foobar 1.1.3 can't read the information embedded in the wave file.  But use EAC to rip "Stages" of Elaine Paige, then use Tag & Rename to add fields and cover art, Foobar can read it.
  • liverbird
Hi Support,
Sorry for the late reply.  I have tried to trim the wave file to 30 seconds music (with Audacity) but after I export the wave file and add the tag, Foobar can read the tag on the new wave file.  As I cannot upload the original file to you, I can't find a way to show you my problem for investigation.  Please advice.
Regards,
John
  • kode54
  • Administrator
You could try compressing the large WAV file with WinRAR and uploading the RAR file to the forum, or if it's still too large, to Mediafire or Dropbox and PM a link to Peter.
  • lvqcl
How big the coverart is? (in bytes)
  • liverbird
22.6KB
  • lvqcl
Then you can upload first ~100 kbytes and last 100 kbytes of this file. I think this should be enough.
