Topic: Extracting FLAC files from CD with EAC (Read 7100 times) previous topic - next topic
  • jaz012
Hi all,
I'm new to all this and have some questions that would be great to have answered. Basically, I would like to make "perfect" or "near perfect" copies of my cd's and rather than do this multiple times, it would be good to get it right the first time (rather than learn of all the mistakes I made at a later date and then redo it). Ideally, I would prefer to keep the copying times somewhat short so I am willing to sacrifice a little quality for that. I did a test run with a CD in different ways so I hope that can help in this discussion.
First off, I went through this configuring the options exactly the way they recommended:
http://wiki.hydrogenaudio.org/index.php?ti...xact_Audio_Copy
[snip]
Secondly, I followed these instructions to try it out:
http://home.scarlet.be/spb2267/
1. There is a default bitrate in “Compression Options” of 768 kBit/s and it says something about how you can ignore this option and customize it later. But I saw no indication of a place to adjust this setting when I did my extraction. So I'm not sure how to proceed with regards to the bitrate and what bitrate level to choose.
2. I used "Test and Copy Selected Tracks - Compressed" in Secure mode and it took 18 minutes for the CD to finish. When I selected "Drive is capable of retrieving C2 error information" in the Drive Options it cut down the time to 10 minutes. I did perform the “Examine C2 Feature” to make sure that my drive can detect those errors and it did find them on a scratched CD so C2 does seem to work. Therefore I assume that this is the best way to do this for me (the Accurate Rip checkbox was checked but greyed out). Is it the best way? If not what is and why?
3. To know that everything went well, I just need to look for the perfect finish and all are "OK" in the CRC catgory, right? I won't be missing anything that I will later regret when it comes to errors etc.?
4. Gaps: Here is my cue sheet (also there are no gaps mentioned in the gap column of EAC except for the first track). The Index numbers seem strange to me. Are they good?:
REM GENRE Soul
REM DATE 2011
REM DISCID B10BDC0E
REM COMMENT "ExactAudioCopy v1.0b3"
PERFORMER "Rod Stewart"
TITLE "The Best Of The Great American Songbook"
FILE "01 Long Ago And Far Away.wav" WAVE
  TRACK 01 AUDIO
   TITLE "Long Ago And Far Away"
   ISRC USJAY0500726
   INDEX 01 00:00:00
FILE "02 Someone To Watch Over Me.wav" WAVE
  TRACK 02 AUDIO
   TITLE "Someone To Watch Over Me"
   ISRC USJAY1000260
   INDEX 01 00:00:00
FILE "03 They Can't Take That Away From Me.wav" WAVE
  TRACK 03 AUDIO
   TITLE "They Can't Take That Away From Me"
   ISRC USJAY0200274
   INDEX 01 00:00:00
FILE "04 Beyond The Sea.wav" WAVE
  TRACK 04 AUDIO
   TITLE "Beyond The Sea"
   ISRC USJAY1000121
   INDEX 01 00:00:00
FILE "05 You'll Never Know.wav" WAVE
  TRACK 05 AUDIO
   TITLE "You'll Never Know"
   ISRC USJAY1000256
   INDEX 01 00:00:00
FILE "06 Time After Time.wav" WAVE
  TRACK 06 AUDIO
   TITLE "Time After Time"
   ISRC USJAY0300312
   INDEX 01 00:00:00
FILE "07 I Can't Get Started.wav" WAVE
  TRACK 07 AUDIO
   TITLE "I Can't Get Started"
   ISRC USJAY0400390
   INDEX 01 00:00:00
FILE "08 The Way You Look Tonight.wav" WAVE
  TRACK 08 AUDIO
   TITLE "The Way You Look Tonight"
   ISRC USJAY0200275
   INDEX 01 00:00:00
FILE "09 Bye Bye Blackbird.wav" WAVE
  TRACK 09 AUDIO
   TITLE "Bye Bye Blackbird"
   ISRC USJAY1000258
   INDEX 01 00:00:00
FILE "10 These Foolish Things.wav" WAVE
  TRACK 10 AUDIO
   TITLE "These Foolish Things"
   ISRC USJAY0200277
   INDEX 01 00:00:00
FILE "11 But Not For Me.wav" WAVE
  TRACK 11 AUDIO
   TITLE "But Not For Me"
   ISRC USJAY0400394
   INDEX 01 00:00:00
FILE "12 What A Wonderful World.wav" WAVE
  TRACK 12 AUDIO
   TITLE "What A Wonderful World"
   ISRC USJAY0400381
   INDEX 01 00:00:00
  TRACK 13 AUDIO
   TITLE "My Foolish Beast"
   ISRC USJAY1000126
   INDEX 00 03:27:04
FILE "13 My Foolish Beast.wav" WAVE
   INDEX 01 00:00:00
FILE "14 I'll Be Seeing You.wav" WAVE
  TRACK 14 AUDIO
   TITLE "I'll Be Seeing You"
   ISRC USJAY0200290
   INDEX 01 00:00:00
  • Last Edit: 29 May, 2012, 03:46:44 PM by db1989
  • Ouroboros
1. You don't choose the bit rate with FLAC. It is lossless, it uses as many bits as it needs. You can change the compression ratio (more compression at the expense of some encoding speed).
3. The log file tells you if it's OK. Configure Accurate Rip to give you some independent validation.
  • db1989
  • Global Moderator
Lossless files do not offer the user an ability to choose a fixed bitrate. This has been discussed numerous times, but see this recent thread: http://www.hydrogenaudio.org/forums/index....showtopic=94926
The purpose of that selector in EAC is simply to provide a very rough visual estimate of the resulting FLAC file size, based upon that bit rate.
Indeed, but the OP should note that this option is not configured using the bitrate selector but rather must be specified in the command-line options. Which I assume s/he has read about in the Knowledgebase’s guide to EAC and FLAC and/or elsewhere.
2. I used "Test and Copy Selected Tracks - Compressed" in Secure mode and it took 18 minutes for the CD to finish. When I selected "Drive is capable of retrieving C2 error information" in the Drive Options it cut down the time to 10 minutes.[…] Therefore I assume that this is the best way to do this for me (the Accurate Rip checkbox was checked but greyed out). Is it the best way? If not what is and why?
Using both Secure Mode and Test and Copy seems redundant; secure mode already does its own re-reading, so why make it do the entire thing twice?
Edit: See the response below from greynol, who knows a lot more about this than me (or most!)
Well, there’s the possibility that your drive may read the same wrong data twice and thus obtain matching CRCs… Again, this has been discussed a lot. I wonder why you were not able to activate AccurateRip? Comparing one’s rips to those of others is a more reliable indicator of accuracy than is reading twice by oneself, even using a secure mode. (Which Ouroboros beat me to saying, again! )
Buuuuut… assuming your discs are in acceptable condition and your drive is competent, Secure Mode is a fairly reliable second-best. For now, at least.
Why?
Are they good?
They simply state that each song begins at the very start of its corresponding audio file, which seems exactly right to me.
  • Last Edit: 29 May, 2012, 04:09:03 PM by db1989
  • greynol
  • Global Moderator
It's redundant only when EAC is told not to rely on C2 error information.  When relying on C2 pointers, the additional test CRC (when matching) provides some confidence that the drive didn't fail to report an error.
Of course positive AccurateRip verification provides greater certainty that a rip is error-free than matching test and copy CRCs.
  • Last Edit: 29 May, 2012, 04:05:59 PM by greynol
  • jaz012
Thank you everyone for your speedy responses. I think perhaps I'm a little overwhelmed by the volume of information that I have attempted to ingest so I hope that helps explain my questions.
One thing it seems that I missed is the comparing with Accurate Rip to see if my version matches others. Is there some documentation that explains how to do this? The configuration documentation is pretty clear and comprehensive but the information about doing the extraction is a little harder to find.
@ Ouroboros:
I believe I read somewhere that "6" is the default compression ratio and is the best choice.
@ db1989:
So I guess I do not need to worry about bitrates then. I had read that page and did copy/paste this command line into the Compression Options as per the configuration instructions:
-T "artist=%artist%" -T "title=%title%" -T "album=%albumtitle%" -T "date=%year%" -T "tracknumber=%tracknr%" -T "genre=%genre%" -5 %source%
@ db1989 and greynol:
I'm pretty confused about what "actions" and settings to use in what combination. I'm guessing that Accurate Rip compares my files with other files done by others. It would be great to do that but also to be able to do an extraction without that as some of the CDs are a bit obscure.
On a side note, the disk I tested this with (Rod Stewart) was brand new just out of the packaging. I just tried again (Trainspotting soundtrack CD) with "Test and Copy Selected Tracks - Compressed" and the C2 box unchecked and it took 48 minutes which is pretty long. It is a fairly well played CD unlike my first test CD.
  • db1989
  • Global Moderator
I’m glad that you’ve found our replies helpful! You’re correct that it can be overwhelming, but I think you’re getting there quickly.
Is the official plugin installed and enabled? The official EAC site’s page about AccurateRip may help you here.
Does not compute
This definitely doesn’t sound right, I must say. What drive do you have? Do you know whether the entire process is slow, or just the gap detection? Short of some major issue with your drive, I suspect you may be using a gap detection method that does not suit it. Here’s a page that discusses some of the potential pitfalls: http://blowfish.be/eac/Setup/setup5.html#no5d
  • greynol
  • Global Moderator
Copy tracks compressed (Shift + F5)
Check AccurateRip results
If AR says they're good then you're done
For tracks AR cannot verify them as accurate, select them and generate a test CRC (F8)
If CRCs match you're done.
The above procedure is valid for all configurations.  If you're using secure mode without C2 error information then generating a test CRC is unlikely to buy you anything.
If you're using C2 error information and test and copy CRCs don't match, try again without C2 error information.
You never told us what drive you're using and if it caches audio data.
Regarding Accurate Rip, the box should either be greyed-out and not checked or it should be configurable.  If it is greyed-out and not checked then feed the drive discs and Accurate Rip will self-configure.  If it is greyed-out and checked then there is something wrong.
  • greynol
  • Global Moderator
Re. Blowfish: UGH!!!
The author has remained pretty anonymous, but I know he reads my posts.  After fixing awkwardly addressing several of the problems I've pointed over the past year or so, that site has gotten rather cumbersome (and I still have my doubts about its content!).  Instead of keeping it clear and concise, it seems like he's chosen to layer what appears to be contradictory information.
I suggest we stick with the wiki approach.  Any errors and/or shortcomings can be addressed more easily without having to rely on the knowledge of just one individual.
  • Last Edit: 29 May, 2012, 05:16:47 PM by greynol
  • db1989
  • Global Moderator
I know you and others have questioned the guide, and I was somewhat apprehensive about referencing it, but it seemed a good example of several pieces of information and warnings about gap detection being collected in one place… which is great for the lazy linker!
Of course you’re correct that a community-based solution is best… so, perhaps we should promote our own section on gap detection from its long-standing status of “TBD”!  It remains there with most of the others. I’d be happy to help if I had more up-to-date experience of using EAC, but I rarely rip nowadays. (FWIW, I’ve just started using XLD when I occasionally do, so I hope to get into a position where I can at least offer help with that, if nothing else.)
  • greynol
  • Global Moderator
  • Last Edit: 29 May, 2012, 05:19:49 PM by greynol
  • jaz012
I believe AR is set up as I could find "Send Accurate Rip Results" in the Database dropdown menu. I clicked on it and got this:
Compressing AccurateRip Results...Ok
Compressing Disc TOCs File...Ok
Compressing Index...Ok
Connecting to AccurateRip server...
Requesting version information...
Clearing socket
Submitting results...
AccurateRip submission sucessful!
Finished Submission.
I hope that is it. Here is a log from my latest rip (the 48 minute one). It lists my drive and gives the "Additional command line options" that "did not compute".
"If you are using EAC 1.0b2 or newer, then in the Additional command line options box, copy and paste the following string:
-T "artist=%artist%" -T "title=%title%" -T "album=%albumtitle%" -T "date=%year%" -T "tracknumber=%tracknr%" -T "genre=%genre%" -5 %source%"
from here: http://wiki.hydrogenaudio.org/index.php?title=EAC_and_FLAC
Exact Audio Copy V1.0 beta 3 from 29. August 2011
EAC extraction logfile from 29. May 2012, 22:31
Various / Trainspotting
Used drive  : SlimtypeDVD A  DS8A5SH  Adapter: 0  ID: 1
Read mode              : Secure
Utilize accurate stream : Yes
Defeat audio cache      : No
Make use of C2 pointers : No
Read offset correction                      : 6
Overread into Lead-In and Lead-Out          : No
Delete leading and trailing silent blocks  : No
Null samples used in CRC calculations      : Yes
Used interface                              : Native Win32 interface for Win NT & 2000
Gap handling                                : Appended to previous track
Used output format              : User Defined Encoder
Selected bitrate                : 768 kBit/s
Quality                        : High
Add ID3 tag                    : No
Command line compressor        : C:\Program Files (x86)\Exact Audio Copy\FLAC\FLAC.EXE
Additional command line options : -T "artist=%artist%" -T "title=%title%" -T
 %source%
TOC of the extracted CD
     Track |  Start  |  Length  | Start sector | End sector
       1  |  0:00.33 |  5:13.20 |        33    |    23527
       2  |  5:13.53 |  3:56.37 |    23528    |    41264
       3  |  9:10.15 | 10:34.58 |    41265    |    88872
       4  | 19:44.73 |  5:09.32 |    88873    |  112079
       5  | 24:54.30 |  7:00.15 |    112080    |  143594
       6  | 31:54.45 |  4:13.50 |    143595    |  162619
       7  | 36:08.20 |  6:00.73 |    162620    |  189692
       8  | 42:09.18 |  3:44.57 |    189693    |  206549
       9  | 45:54.00 |  4:31.55 |    206550    |  226929
       10  | 50:25.55 |  6:27.68 |    226930    |  256022
       11  | 56:53.48 |  2:33.40 |    256023    |  267537
       12  | 59:27.13 |  3:15.60 |    267538    |  282222
       13  | 62:42.73 |  9:44.45 |    282223    |  326067
       14  | 72:27.43 |  3:09.00 |    326068    |  340242
Track  1
     Filename C:\Users\Other\Desktop\eac test - 111\3\01 Iggy Pop - Lust For Life.wav
     Pre-gap length  0:00:02.33
     Peak level 87.2 %
     Extraction speed 2.1 X
     Track quality 100.0 %
     Test CRC 2FD6F989
     Copy CRC 2FD6F989
     Accurately ripped (confidence 21)  [29A8D84D]  (AR v2)
     Copy OK
Track  2
     Filename C:\Users\Other\Desktop\eac test - 111\3\02 Brian Eno - Deep Blue Day.wav
     Pre-gap length  0:00:01.28
     Peak level 81.5 %
     Extraction speed 2.3 X
     Test CRC 23D9CBD3
     Copy CRC 23D9CBD3
     Accurately ripped (confidence 23)  [F48209FB]  (AR v2)
     Copy OK
Track  3
     Filename C:\Users\Other\Desktop\eac test - 111\3\03 Primal Scream - Trainspotting.wav
     Peak level 90.9 %
     Extraction speed 2.6 X
     Track quality 99.9 %
     Test CRC 92F2EADB
     Copy CRC 92F2EADB
     Accurately ripped (confidence 23)  [06EE9F29]  (AR v2)
     Copy OK
Track  4
     Filename C:\Users\Other\Desktop\eac test - 111\3\04 Sleeper - Atomic.wav
     Pre-gap length  0:00:01.53
     Peak level 92.5 %
     Extraction speed 2.9 X
     Test CRC 6EF9F273
     Copy CRC 6EF9F273
     Accurately ripped (confidence 23)  [13B12EE3]  (AR v2)
     Copy OK
Track  5
     Filename C:\Users\Other\Desktop\eac test - 111\3\05 New Order - Temptation.wav
     Pre-gap length  0:00:00.62
     Peak level 88.3 %
     Extraction speed 3.1 X
     Test CRC 61F0961C
     Copy CRC 61F0961C
     Accurately ripped (confidence 23)  [14F6AB18]  (AR v2)
     Copy OK
Track  6
     Filename C:\Users\Other\Desktop\eac test - 111\3\06 Iggy Pop - Nightclubbing.wav
     Pre-gap length  0:00:00.70
     Peak level 90.0 %
     Extraction speed 3.3 X
     Test CRC 3D598BEA
     Copy CRC 3D598BEA
     Accurately ripped (confidence 23)  [CCB07A0F]  (AR v2)
     Copy OK
Track  7
     Filename C:\Users\Other\Desktop\eac test - 111\3\07 Blur - Sing.wav
     Pre-gap length  0:00:01.15
     Peak level 92.5 %
     Extraction speed 3.5 X
     Test CRC 8189155D
     Copy CRC 8189155D
     Accurately ripped (confidence 21)  [750C7DFC]  (AR v2)
     Copy OK
Track  8
     Filename C:\Users\Other\Desktop\eac test - 111\3\08 Lou Reed - Perfect Day.wav
     Pre-gap length  0:00:00.53
     Peak level 92.5 %
     Test CRC C514730C
     Copy CRC C514730C
     Accurately ripped (confidence 23)  [3377659A]  (AR v2)
     Copy OK
Track  9
     Filename C:\Users\Other\Desktop\eac test - 111\3\09 Pulp - Mile End.wav
     Pre-gap length  0:00:00.55
     Peak level 92.4 %
     Extraction speed 3.6 X
     Test CRC 284A9A3B
     Copy CRC 284A9A3B
     Accurately ripped (confidence 22)  [5135A8CD]  (AR v2)
     Copy OK
Track 10
     Filename C:\Users\Other\Desktop\eac test - 111\3\10 Bedrock feat. KYO - For What You
 Dream Of.wav
     Pre-gap length  0:00:01.25
     Peak level 98.0 %
     Extraction speed 3.9 X
     Test CRC 5367541F
     Copy CRC 5367541F
     Accurately ripped (confidence 23)  [2052828A]  (AR v2)
     Copy OK
Track 11
     Filename C:\Users\Other\Desktop\eac test - 111\3\11 Elastica - 2-1.wav
     Pre-gap length  0:00:01.13
     Peak level 83.2 %
     Extraction speed 4.0 X
     Test CRC 1915CDBB
     Copy CRC 1915CDBB
     Accurately ripped (confidence 23)  [9FE81541]  (AR v2)
     Copy OK
Track 12
     Filename C:\Users\Other\Desktop\eac test - 111\3\12 Leftfield - A Final Hit.wav
     Peak level 69.6 %
     Test CRC 62AA19BC
     Copy CRC 62AA19BC
     Accurately ripped (confidence 22)  [912C3066]  (AR v2)
     Copy OK
Track 13
     Filename C:\Users\Other\Desktop\eac test - 111\3\13 Underworld - Born Slippy.wav
     Pre-gap length  0:00:00.40
     Peak level 77.6 %
     Extraction speed 4.1 X
     Test CRC FD4824A4
     Copy CRC FD4824A4
     Accurately ripped (confidence 22)  [F64391A2]  (AR v2)
     Copy OK
Track 14
     Filename C:\Users\Other\Desktop\eac test - 111\3\14 Damon Albarn - Closet Romantic.wav
     Peak level 94.4 %
     Extraction speed 4.3 X
     Test CRC DDC7B096
     Copy CRC DDC7B096
     Accurately ripped (confidence 22)  [8B0B3F5B]  (AR v2)
     Copy OK
All tracks accurately ripped
No errors occurred
End of status report
@ db1989: I'm not sure if the gap detection is working well. I did do "detect gaps" in "actions" before the copying and it did fill in the "Gap" column.
@ greynol: I think the configuration wizard detected that my drive did not cache audio data but that was a few days ago so I'm not sure if I remember that correctly. The AccurateRip box is configurable unless I select the C2 option then it becomes greyed out (but it does stay checked).
P.S. apologies for the missing codebox but my attempt seems to not have worked. Also, it seems the log file lists the same info twice. Is that normal?
  • Last Edit: 29 May, 2012, 05:48:37 PM by greynol
  • db1989
  • Global Moderator
How long does the detection process take? That’s what I meant: if it takes ages, you should try another option and see if that speeds things up (hopefully dramatically). Otherwise, we still need to get some idea of which part of the extraction is taking such an inordinate amount of time.
Instead of what you did, do this:
[codebox]tonne o’ text[/codebox]
And I don’t know why you have two reports in the one log (assuming you didn’t paste twice, but I think you’d know if you did ).
  • greynol
  • Global Moderator
Other than to show pregap information in the log file, there is no reason to detect gaps before ripping.  If you aren't interested in maintaining gap information in a CUE sheet in order to burn a copy at a later date with this information intact, there is no reason to detect gaps at all.
No AR support when C2 error information is enabled?  Is this new behavior? It sounds like a bug to me!  Can anyone else confirm?
EDIT: I just installed the latest version of EAC and cannot confirm that enabling the use of C2 pointers disables AR.
Regarding the redundant log (which I removed from your last post), you do not need to tell EAC to generate a log if you have it configured to do so automatically.
  • Last Edit: 29 May, 2012, 06:10:29 PM by greynol
  • db1989
  • Global Moderator
Aren’t gaps detected during the process of ripping to an image and cue-sheet in all cases? I ask because, IIRC, we often advise users not to run the manual check before ripping to an image, as it’s a redundant step. As for the cosmetic feature of including gaps in the log, I assumed for the same reason that image-based rips would already have this, but this may not be the case (knowing me ).
As I understood it, the only purposes of manual detection are (1) as a necessary prelude to non-standard positioning of INDEX 00s in per-track rips and (2) to include details about gaps in the log of rips with gaps in the standard location, i.e. appended to the previous track.
  • greynol
  • Global Moderator
Yes, EAC will automatically detect gaps whenever it is instructed to create a cue sheet; either separately or as part of the image+cue ripping process.  That I implied cue sheets could be created by EAC in such a way as not to include gap information (assuming the original disc has 00 indices) or one needs to detect gaps manually in order to create a cue sheet was an unfortunate mistake as neither of these are true.
I'm pretty sure single-file image rips do not include pregap information in the log, regardless of whether gap detection is performed manually or automatically.  I don't rip single-file images, however.
As well as (3) to display the gap sizes in the GUI, (4) to extract tracks, index-based and (5) to "Test Gaps On Silence" (which is misleading and hence completely useless to those who want to preserve data in order to maintain a lossless copy) you are absolutely correct.
Let me amend what you quoted to say cue sheets are not necessary unless one wants to burn a copy that maintains gap information with the notable exception that a CUE sheet is the only place EAC keeps a record of whether the original disc has the pre-emphasis flag enabled.  No use for a cue sheet means no reason to do anything with gaps, though my preferred way to extract HTOA requires gap detection, falling under my (4).
  • Last Edit: 29 May, 2012, 07:39:13 PM by greynol
  • jaz012
@ db1989: It seems that each song takes about 3-5 minutes to complete and there are 14 of them. About 1/2 the time is the "test" and the other 1/2 is the "copy". Nothing seems to take longer than anything else, it seems to run at a uniformly slow rate. And I don't see any mention of gap detection during the process (however, there is some interesting info regarding gaps in the first link below. I don't think I chose these settings). This is a fairly well used disc that is a few years old but at the same time in fairly good condition (no scratches).
As for the two reports, it wasn't a double paste  . It may have put two in there because it autogenerated a log and I pressed "Create Log" when the extraction was finished.
@ greynol: It seems that making the cue sheets is quick and painless and I would want to be thorough so I am interested in doing that too. Who knows if one day I will be transferring it back to disk.
As for the AR and C2, hopefully this will help:
And here is a screenshot of the "Copy Selected Tracks - Compressed" in action. It was faster than Test and Copy:
  • greynol
  • Global Moderator
AccurateRip (AR) and accurate stream are two completely different things.  The AccurateRip checkbox is located on the offset/speed tab.
I already knew you didn't paste the log twice.
What kind of speeds do you get with the C2 error information setting enabled?  What do you get with burst mode?
  • jaz012
Oops. Now I know why I was being so confusing with Accurate Rip.
So far I have done:
Standard Test and Copy: 48 minutes
Standard Copy: 25 minutes
Test and Copy with C2 Error Information: 16 minutes (with one error - see log)
Test and Copy with Burst Mode: 15 minutes
So if I understand all this correctly, then these three magic lines need to look like this in order for me to have the perfect rip:
No errors occurred
Also, as I do want to make cue sheets and get this gap thing right, should I change the setting (in the screenshot in my previous post)?
Lastly, is it this line for each track that tells you that Accurate Rip made an accurate match: "Accurately ripped (confidence 23)  [06EE9F29]  (AR v2)"
If that is the case, what if you are not online?
EAC extraction logfile from 31. May 2012, 20:51
Read mode              : Secure
Make use of C2 pointers : Yes
Gap handling                                : Not detected, thus appended to previous track
Quality                        : High
Add ID3 tag                    : No
Additional command line options : -T "artist=%artist%" -T "title=%title%" -T "album=%albumtitle%"
Track  1
     Filename C:\Users\Other\Desktop\eac test - 111\5\01 Iggy Pop - Lust For Life.wav
     Peak level 87.2 %
     Extraction speed 6.6 X
     Test CRC 2FD6F989
     Copy CRC 2FD6F989
     Copy OK
Track  2
     Filename C:\Users\Other\Desktop\eac test - 111\5\02 Brian Eno - Deep Blue Day.wav
     Peak level 81.5 %
     Extraction speed 7.1 X
     Test CRC 23D9CBD3
     Copy CRC 23D9CBD3
     Copy OK
Track  3
     Filename C:\Users\Other\Desktop\eac test - 111\5\03 Primal Scream - Trainspotting.wav
     Peak level 90.9 %
     Extraction speed 8.1 X
     Test CRC 92F2EADB
     Copy CRC 92F2EADB
     Copy OK
Track  4
     Filename C:\Users\Other\Desktop\eac test - 111\5\04 Sleeper - Atomic.wav
     Peak level 92.5 %
     Extraction speed 8.7 X
     Test CRC 6EF9F273
     Copy CRC 6EF9F273
     Copy OK
Track  5
     Filename C:\Users\Other\Desktop\eac test - 111\5\05 New Order - Temptation.wav
     Peak level 88.3 %
     Extraction speed 9.6 X
     Test CRC 61F0961C
     Copy CRC 61F0961C
     Copy OK
Track  6
     Filename C:\Users\Other\Desktop\eac test - 111\5\06 Iggy Pop - Nightclubbing.wav
     Peak level 90.0 %
     Extraction speed 9.8 X
     Test CRC 3D598BEA
     Copy CRC 3D598BEA
     Copy OK
Track  7
     Filename C:\Users\Other\Desktop\eac test - 111\5\07 Blur - Sing.wav
     Peak level 92.5 %
     Extraction speed 10.6 X
     Test CRC 8189155D
     Copy CRC 8189155D
     Copy OK
Track  8
     Filename C:\Users\Other\Desktop\eac test - 111\5\08 Lou Reed - Perfect Day.wav
     Peak level 92.5 %
     Extraction speed 11.0 X
     Test CRC 935B43C3
     Copy CRC 935B43C3
     Cannot be verified as accurate (confidence 177)  [2453E715],
       AccurateRip returned [4788DB96]  (AR v2)
     Copy OK
Track  9
     Filename C:\Users\Other\Desktop\eac test - 111\5\09 Pulp - Mile End.wav
     Peak level 92.4 %
     Extraction speed 11.1 X
     Test CRC 284A9A3B
     Copy CRC 284A9A3B
     Copy OK
Track 10
     Filename C:\Users\Other\Desktop\eac test - 111\5\10 Bedrock feat. KYO - For What You Dream Of.wav
     Peak level 98.0 %
     Extraction speed 11.9 X
     Test CRC 5367541F
     Copy CRC 5367541F
     Copy OK
Track 11
     Filename C:\Users\Other\Desktop\eac test - 111\5\11 Elastica - 2-1.wav
     Peak level 83.2 %
     Extraction speed 11.6 X
     Test CRC 1915CDBB
     Copy CRC 1915CDBB
     Copy OK
Track 12
     Filename C:\Users\Other\Desktop\eac test - 111\5\12 Leftfield - A Final Hit.wav
     Peak level 69.6 %
     Extraction speed 12.2 X
     Test CRC 62AA19BC
     Copy CRC 62AA19BC
     Copy OK
Track 13
     Filename C:\Users\Other\Desktop\eac test - 111\5\13 Underworld - Born Slippy.wav
     Peak level 77.6 %
     Extraction speed 13.1 X
     Test CRC FD4824A4
     Copy CRC FD4824A4
     Copy OK
Track 14
     Filename C:\Users\Other\Desktop\eac test - 111\5\14 Damon Albarn - Closet Romantic.wav
     Peak level 94.4 %
     Extraction speed 12.5 X
     Track quality 99.8 %
     Test CRC DDC7B096
     Copy CRC DDC7B096
     Copy OK
13 track(s) accurately ripped
 1 track(s) could not be verified as accurate
Some tracks could not be verified as accurate
No errors occurred
  • Last Edit: 31 May, 2012, 05:10:49 PM by greynol
  • pdq
In case it has not been mentioned, you do not need test and copy if your results match the AccurateRip database. Only if you do not get a match do you need to use a more secure ripping method.
  • greynol
  • Global Moderator
Test and copy will always take twice as along as a copy since the test pass is the identical operation as the copy pass except that the extracted audio is not written to your hard drive.  This is ignoring additional time when encoding to a compressed format, of course.
A rip using C2 pointers and no cache flushing should take about the same time as a burst rip, so that's good too.  That said I'd expect to see at least double the ripping speed, but performance with EAC depends on the drive and the disc and can vary wildly.
No errors occurred
"All tracks accurately ripped" is the single most compelling line.  The following line is irrelevant in this situation.  FWIW the "No error occurred" is solely based on EAC's internal criterion for what constitutes a good rip and is completely independent from the previous line (or lines) that are derived from AccurateRip results.  Further, EAC's internal criterion is independent and separate from AccurateRip results.  EAC does not do anything with AccurateRip results but report them.  As a result, it is quite possible to see:
There were errors
...in which case "There were errors" can be ignored.
You may also see EAC say there were no errors but also see that some tracks cannot be verified by AccurateRip, which is an inconclusive case.  Depending on other factors such as whether unverified tracks caused EAC to perform re-reads, the confidence level of all the tracks that were verified, or the condition of the disc you might have reason to believe AR over EAC or vice-versa when they contradict one another.  Your latest log which I'll address shortly falls under this category.
The wiki should be clear on this (or changed if not).  There is no single right way to configure the gap detection settings.  If there was then they wouldn't be there in the first place.  What is best for your drive (and to a much lesser extent, the disc) depends on what works the fastest and gives results that make sense.
You'll know when you encounter it.
Track  8
     Peak level 92.5 %
     Test CRC 935B43C3
     Copy CRC 935B43C3
     Copy OK
No errors occurred
I would try this track again with in burst mode or in secure mode with the C2 option disabled and see if you get a different result.  Because the other tracks were verified with a good level of confidence (~22), I'm inclined to believe AR and not EAC.
  • Last Edit: 31 May, 2012, 05:24:54 PM by greynol
  • JJZolx
What's the explanation for this? The logging for the other tracks would lead me to believe that about 23 people have submitted this pressing of the same CD to the AR database. But that _one_ track in the middle of the CD has 177 entries in the AR database, and happens to be the only mismatch? How does that happen?
  • pdq
Very simple - that track is not accurate.
  • Ouroboros
177 entries vs 23 presumably because 23 people have ripped and submitted results for the whole album, while 154 people have ripped and submitted results for only that one track from the album?
  • Last Edit: 31 May, 2012, 06:57:02 PM by Ouroboros
  • greynol
  • Global Moderator
154 people have ripped and submitted results for only that one track.
That's not right.
177 is the number from the first pressing element for that track in the record, which is what AR provides when it cannot match the hash.
EDIT: The word "pressing" was stricken and replaced with "element for that track" since individual hashes and their associated confidences only implies different pressings, it does not guarantee they are all from different pressings.  Subtle difference?  Perhaps, but it helps to paint a more accurate picture of how the AR system works, even if it means having to understand that things aren't always all that simple.
  • Last Edit: 31 May, 2012, 07:04:00 PM by greynol
  • JJZolx
177 is the number from the first "pressing" in the record, which is what AR provides when it cannot match the hash.
So you fail to get an AR match and what is returned is a confidence number (and CRC?) from a different pressing?? Can't it easily figure out the pressing by the other 12 of 13 tracks on the CD? If the confidence number shown were 21/22/23 then it would be readily apparent (to me, anyway) that AR found the right track in its database, without my having to understand the quirks of the whole process in detail.
