Topic: iTunes’ on-the-fly conversion uses which bitrate profile—CBR/VBR/ABR? (Read 2006 times) previous topic - next topic
  • geeuhnfay
iTunes gives the option to convert higher bitrate songs to 128, 192, and 256kbps AAC.
I'm wondering what settings the conversion would be in and if the built in iTunes encoder for AAC is recommended over Nero AAC
You should determine this for yourself.  You aren't going to find a straight answer to "iTunes is better at XXXkbps and Nero is better at YYYkbps."  Both encoders are nice as-is and, once you get up to the higher bitrates, they will start sounding the same except for a few problematic samples.  The best thing you can do is encode with iTunes at a few different settings (start out low) and conduct a handful of blind ABX tests.  That way you can come up with a consensus for yourself as you aren't going to find a general one here.
  • geeuhnfay
I was wondering how iTunes converts the files on the fly because it doesn't specify. Is it VBR, CBR, etc?
It is CBR. I personally  use 128 for my iPod i find the quality very excellent. Any higher i find it a waste of space in my opinion.
