Topic: foo_input_usf: installed but can’t play files, says “Object not found” (Read 1099 times) previous topic - next topic
i have installed the .dll for the .USF and .MINIUSF, but i cannot play it. i get this error even though i have it:
Unable to open item for playback (Object not found):
"C:\Users\*******\Desktop\Intro.miniusf"
i have the music for Mario Golf and it is located on my desktop. but it says it cannot be found! any help?
  • lvqcl
I don't use this format but it looks like you also need some .usflib file.
OK, i have found the file:
NUS-NMFE-USA.usflib  -  which the file name is the serial number for Mario Golf.
where do it put it? and use it?
  • db1989
  • Global Moderator
It would be an idea to try putting it in the same folder as the main USF file with the same name.
it works! thank you!
