Topic: Not recognizing metadata from official release CD (Read 1377 times) previous topic - next topic
  • gregsolo
I'm not an engineer so go easy on me.  After inserting disc no tagging is applied.
Also, I have Windows 7 and I can't for the life of me figure out how to make Foobar the default player.  I've know how with other programs up until now.
Thanks for your help.  -G
  • Erich_2
... and I can't for the life of me figure out how to make Foobar the default player...
File > Preferences > Shell Integration > Manage file type associations
and "Set as the default Audio CD Player", if you want...
  • db1989
  • Global Moderator
Just installed 1.1.11
Did you also install the optional freedb tagger?
  • gregsolo
Looks like it's set as a default...or a grey check.  Not happening though.  Thanks anyway.
  • gregsolo
I didn't see the option during installation and I've searched Foobar for it.  Thanks for your help.
  • db1989
  • Global Moderator
It’s only available as a bundled plugin. You can run the installer again and add it, with no risk of losing anything you’ve saved since you initially installed.
  • gregsolo
You made my day.  That was so easy.  While it's set as my default player, it still doesn't fire up when throw in the CD and worse I have to manually request tagging.  I'll keep reading.  Thanks again.
