Topic: Displaying Albums( don't having artwork) (Read 1768 times) previous topic - next topic
  • prateek88
I wonder is there any way to make the foobar display only those albums which dont have artwork, so that i can manage them easily. using facets, simplaylist.
  • neothe0ne
You can do this filter in mp3tag
or in other words: no, it's not possible in foobar2000!
however, i'll desire that feature too but i think it requires something like a cache that also could mmade image loading in several parts of fb2k (f.e. facets) faster? (more a question than a claim)
german support forum: www.foobar-users.de / user: qwert73
  • prateek88
yes, that would be a good move though this could result in performance vs memory trade-off. So for now should i assume that i have to keep searching manually every album and fix it (seems weird).
  • Mr.Duck
You could try some sort of batch file to check each folder, look for a folder.jpg file, then print the full path if the file was not found.
  • neothe0ne
If your artwork is in your song files, like I said, you can do it in Mp3tag.
Quote from: http://help.mp3tag.de/main_filter.html link=msg=0 date=
%_covers% IS ""
All files that do not contain cover art.
  • wolfsong
It seems fairly odd that there is not a way to do a basic search for files where the tag is missing in F2K since you can use F2K to embed the artwork in the tags. It's not clear why something like
%cover% MISSING
isn't implemented for use in a search, facets or autoplaylists.
  • Anomalous
foo_covers should be able to do this. Unfortunately, queries such as
%albumart_front% MISSING
cause foobar to become unresponsive.
You could get around this by checking a smaller number of songs at a time, or adding %albumart_front% as a custom column and scrolling down to see if any are missing.
  • Last Edit: 28 May, 2012, 05:33:52 AM by Anomalous
  • prateek88
%_covers% IS ""
ahhhh....this seems to be useful, i will definitely try this thanks for the tip.  btw most of the covers are in tags only.
  • wolfsong
Is this even being developed anymore? There doesn't even appear to be a download for it.
