Topic: Question about Lepai Tripath Class-T Hi-Fi Audio Mini Amplifier (Read 2626 times) previous topic - next topic
  • downdahill
I have a 2 bookshelf speaker (50 watts 08 omhs each speaker) laying around the house unused. Just wondering if i can use  Lepai Tripath Class-T Hi-Fi Audio Mini Amplifier with that bookshelf speakers spec? I mainly want to use the amp for my desktop pc.
Lepai-Tripath-Class-T-Amplifier
http://www.amazon.com/Lepai-Tripath-Class-...cm_cr_pr_sims_t
Yes it will work.
The most serious problem with most switchmode power amps is that their frequency response depends on the speakers they are hooked to. Not a horrible problem, but one that is potentially slightly audible.
  • hlloyge
How so? I've never heard of that, care to explain, or give a link with explanation?
It's a problem common to most switchmode amps - there is a low pass filter on their output that has increasing reactance even within the audio band. The filter is outside any feedback loop.
  • downdahill
Yes it will work.
Is this Lepai amp setup better than a desktop speakers and will it sound better.
