Topic: Recently added autoplaylist (Read 1308 times) previous topic - next topic
  • jazzy73
Hi everybody!
I´m trying to do and autoplaylist were are shown my latest albums added to my library but I can´t get it like I want..
In this playlist I want more recent albums at the top of the list I tried this: %last_modified% SINCE 2012 SORT DESCENDING BY %last_modified%
but it has two problems:first all the tracknumbers are non-sorted and some tracks in some albums are splitted in diferents (altouht is the same)albums..
Which string should I put??
thanks!!
  • MDMA
you need foo_playback_statistics and then you can use the %added% tag
  • jazzy73
Yess!now is perfect thanks!!!
  • jazzy73
mmmm I´ve noticed one thing...How could I filter .cue files from an autoplaylist?
  • Andreasvb
Try if this works:
Include: %path% HAS .cue
Exclude: NOT %path% HAS .cue
  • jazzy73
Try if this works:
yess it works!!
I put this string: %added% SINCE 2012 AND NOT %path% HAS .cue SORT DESCENDING BY %added%
.cue are filtered!the only thing I don´t know is why some albums(not all of them)have their tracknumbers unsorted..
thanks!!
  • Andreasvb
You sort them by %added%?
  • jazzy73
yes,is the only way to show most recently added at the top of the list.
  • ojdo
A compromise could be to sort descending by "$day(%added%)" [the double quotes included in the query!].
  • jazzy73
mm surely I´m doing something wrong..not workin..
