Topic: What Form of Rating/Playcount am I using? (Read 1284 times) previous topic - next topic
  • ca5k
Hey hey guys
I have Playlist Tools, Quick Tagger and foo_playcount all installed and I'm not too sure what one I have been using (for around a year or so)
I want to have the ratings and playcounts write to the actual tags, but I don't know what does what at this moment
I use quick tagger to assign shortcuts (ie CTRL + 2 for 2 stars etc etc) and every now and then I restart foobar to avoid losing any play data if it was to crash on me
so does anyone know what I am doing right/wrong to be able to view the ratings in the actual tags?
Cheers
  • D.Sync
Hey hey guys
Cheers
It's actually quite easy to check. Do a media library search and enter the following query 'rating PRESENT'. This will return all tracks that have the RATING tag embedded into the file itself.
Then do a '%rating% PRESENT' search. This will return all tracks that have the rating stored in other format (e.g. Playback Statistic, customdb etc.).
It's actually a matter of preference of whether to store the rating in the song or not. If you do a lot of backup (differential backup that compares the modified time), storing rating in the file will cause that file to be backup, which is kinda useless. On top of that, rating is a subjective matter and it wouldn't make sense to store it into the file tag itself if you share your music with others.
  • marc2003
if you have foo_playcount installed but want to see rating tags from your files, you need to use $meta(rating) in your custom columns, panels etc...
  • ca5k
Thanks for the heads up
Interestingly my rating PRESENT shows 888 results and my %rating% PRESENT shows 705
If the ratings are being stored to the tag, how would I go about seeing them/editing the rating or playcount outside of Foobar
Also, I don't share my music and the PC my music is on is only used by myself - so how would I go about seeing or editing the actual tag, say with MP3Tag or the likes?
