Topic: MP3 data from AVI (Read 2608 times) previous topic - next topic
  • Dologan
  • Members (Donating)
MP3 data from AVI
Does anybody know of an utility that can be used to extract the MP3 data from a DivX AVI? And I mean extracting the MP3 file, not the audio data into WAV. I've tried to extract it into the WAV using VirtualDub, but apparently the data is somehow corrupted, because the decoder ACM reports an error and halts near the end of the file, leaving me with an incomplete WAV.
I thought that having the MP3 data extracted intact might give me more chances to decode the MP3 using a command-line decoder, Winamp or whatever and not through ACM; but I haven't found a way to do that.
I know this might be kinda off-topic and I should be posting this in Afterdawn or Doom9 forums, but first I am not registered there and secondly I know people here tend to be knowledgeable about many topics and so someone might have a clue.
Thanks,
~Dologan
  • userXYZ
MP3 data from AVI
A short search with google revealed this: http://www.aviexpert.com/
From reading the description of 'Advanced AVI Splitter' I assume that's what you're looking for.
If not then you might want to use this link from my search:
google search for extract AND mp3 AND from AND avi
  • Last Edit: 17 May, 2003, 03:59:20 AM by userXYZ
  • mp3chan
MP3 data from AVI
Virtual Dub Mod 1.5.1.1a will do it all. Just open the movie and look at the stream list select mp3 track and demux it. It's also working with the other formats (AC3, VBR MP3, OGM).
[span style='font-size:8pt;line-height:100%']edit: I've changed the link. Thanx, userXYZ![/span]
  • Last Edit: 17 May, 2003, 05:07:53 AM by mp3chan
  • userXYZ
MP3 data from AVI
Please edit your link!  http://www.doom9.org/
  • Dologan
MP3 data from AVI
Thanks for the help!
I ended up not extracting the MP3 (VBR, btw) data from the AVI, because VirtualDubMod's built-in MP3 decoding engine managed to decode it to WAV just fine. No demuxing was needed.
Thx again.
~Dologan
  • mobius
MP3 data from AVI
The save wave feature in VirtualDub will save the audio stream to a wav container.  This file has a RIFF header but will contain the audio data in whatever form it was in (mp3, ac3, etc.).  CDex will strip this header for you.
Gur svggrfg funyy fheivir lrg gur hasvg znl yvir. Jr zhfg ercrng.
