Topic: How do I disable WAV file tagging? ([FLAC|CD]-->WAV) (Read 1233 times) previous topic - next topic
When ripping a CD to WAV or when converting FLACs to WAV, how can I disable tagging of the resultant WAV files?
I prefer having a simple way to just set foobar to just NOT tag WAVs so I don't have to go back and remove the tags from them if I don't want them.
Any solutions would be appreciated.  Thanks.
opinion is not fact
I'm interested in this too. It seems to have come up recently.
  • Kohlrabi
  • Global Moderator
What is the problems with the tags? Incompatibility with other software?
If the current behaviour leads to problems, maybe Peter will consider a Converter option allowing to not copy any metadata to the target files.
  • Last Edit: 02 June, 2012, 03:42:40 PM by Kohlrabi
  • db1989
  • Global Moderator
And/or a toggle for WAV metadata in Advanced preferences > Tagging, as with other tagging formats for which options are offered.
  • naturfreak
@db1989
+1
for that proposal
  • Peter
  • Administrator
+1 to "What is the problem with the tags? Incompatibility with other software?"
