Topic: Is it possible to download the foobar v1.0 SDK? (Read 2286 times) previous topic - next topic
  • c_j_bolt
Hi All,
I'm trying to extend the 3rd party component foo_bpm. It seems to have been dormant since April 2010. I can build the source for the last version of foo_bpm (0.2.4.1) with the current SDK (2011-03-11). However it fails to load in foobar due to the missing DLL or wrong foobar major version number notification. I think this is probably because I am mixing an old component source with the latest SDK. Is this possible? I'm certain the author, Fraganator, would have built it in the V1.0 SDK circa Jan - April 2010.
I'm learning component development, but have verified my SDK setup like I say I can sucessfully make a DLL and can get the tutorial component to build and load just fine.
Can anyone advise me on where I could get the V1 SDK in order to try building the foo_bpm source with that?
Chris
  • Zao
  • Developer (Donating)
There shouldn't really be any significant differences between the current SDK and the older ones, interface-wise.
There is however a minimum foobar2000 version required for components compiled with a particular SDK, due to the introduction of newer interfaces, which also is bumped when incompatible changes are made, which should be very seldom.
Are you trying to load a component built with a new SDK in an old foobar2000? If so, upgrade your foobar.
  • c_j_bolt
No, I'm using the current SDK and latest stable foobar (v1.1.11). Perhaps I have another problem - I'm aware its a bit clutching at straws, but I can't think why the last released foobar DLL loads ok, yet the one I have built doesn't. Of course I have checked that it is statically linked.
One thing I did notice was that visual studio 2010 professional doesn't seem to have a one to one mapping with its ATL files with the ATL in WT8.0 (the headers of which I am using to get the ATL Helper project to build). This shouldn't affect anything at runtime, right? I think any missing dependencies would just affect compile and link time problems.
I'm new to a lot of the more library specific stuff as my day job is in embedded C software.
  • Zao
Throw your DLL at Dependency Walker and see if there's any DLL except for the usual suspects (shared/ieshims) that is missing. You might be missing some runtime of a library you're built against.
  • Last Edit: 18 May, 2012, 06:12:37 AM by Zao
  • c_j_bolt
Thanks, that's a big help. I can immediately see that some dependencies are missing in the built dll; MSJava.dll, shared.dll and libfftw3-3.dll. The last is an open source fft library specific to foo_bpm component - I can check the path for that. shared.dll I assume is ok from your comment. That just leaves the msjava.dll. I'll see what I can do... Cheers
EDIT: FIXED! thanks, the name of the DLL for the fft was typo'ed, so it couldn't find this. what a great tool dependency walker is - thanks for introducing me to that.
  • Last Edit: 18 May, 2012, 06:43:56 AM by c_j_bolt
  • Zao
msjava.dll is like ieshims.dll one of those false positives that never are there.
shared.dll is provided by fb2k at load time, so that's indeed not a problem.
