Topic: burned vs stamped (Read 850 times) previous topic - next topic
  • B7k
burned vs stamped
My qustion to the forum is their any diffrence between me burning a cd useing flac files vs buying a stamped cd in a store?
  • tpijag
burned vs stamped
IF the Flac files were ripped correctly to begin with and you use them to burn / transfer to a CD as an AUDIO CD, then there should be no quality differences.
If you use the Flac files to burn / transfer to a CD as Flac files, you have made a DATA CD and will likely have trouble getting hardware to play correctly if at all.
  • B7k
burned vs stamped
whats the diffrence in the software modes "disk at once", "track at once" do they write the bits diffrently is one mode better then the other?
