Topic: Custom Column: File changed (Read 469 times) previous topic - next topic
  • Jackie78
I guess the "Custom Column" Feature in Foobar needs some detailed explanation, unfortunaely the Wiki is not very helpful here. What I want to add is a column that contains the date when a file on disk was last changed, like in Windows explorer. So I can always see the files I added last to my directory on top (sortable). There are some default file-columns available, unfortunately none related to the filedate.
Note: this is not the same as the date in the ID3 tag, just if somebody wonders
Thanks a lot for all your help.
Regards,
Jackie
  • marc2003
