Topic: Is it possible to send 2 separate signals into guitar amp w/ 1 input? (Read 3754 times) previous topic - next topic
  • replicait
Hi all,
Is it possible to send two separate audio signals (one from a guitar, the other fx from a MOTU output) into a basic guitar amplifier, using a Y-split cable or similar?
In an ideal world:
Guitar  > DI > SPLIT [One signal to the audio desk for FOH speaker send, the other into the amplifier] & an output from the MOTU into that same amplifier.
It only needs to play back a few effects cues, not music, so I'm not too worried about the audio quality.
Any advice would be great.
Many thanks
  • pdq
It is never a good idea to connect two outputs together, but there are inexpensive devices called mixers that will do the job. Even less expensive would be to place a resistor in series with each of the sources to safely combine them. Choice of resistor values would control the relative signal strength of the two signals.
  • mixminus1
Also keep in mind the extreme differences in signal levels you're looking at:  output from a guitar is in the microvolt range (especially single-coil pickups), the output from your MOTU interface's line out will be in the millivolt-to-volt range, i.e. orders of magnitude higher.
You will need to greatly reduce the output from the MOTU using a resistive pad, as pdq suggested, before mixing the two signals together.
  • DVDdoug
And, there are impedance differences...    Guitar inputs are unique.  They are neither line or microphone compatible.    (I thought the voltage is higher than microvolts...  I thought it was nearly line-level with a high impedance load of 1M ohm or more.).
I don't know if there's an existing mixer with both line & instrument inputs, and an instrument output.  It would be an easy thing to build... for someone who knows how to build op-amp circuits.
Someone might make a pedal with an guitar-in plus a line-in, but I don't know.    Almost everything with a guitar-input and a guitar-output is some kind of pedal...
Or, if you have a guitar amp with two inputs (which means it has a little built-in mixer), you can probably plug-in the MOTU, turn down the MOTU output a bit, and turn-down the gain for the channel the MOTU is plugged-into and get a reasonable mix.    Someone might make an amp-head with a line input?
  • Last Edit: 23 April, 2012, 01:50:40 PM by DVDdoug
What sort of DI box are you using?
A DI box usually has a balanced output to feed into a low impedance mic input.  Connecting the output to an unbalanced guitar input could cause hum in your FOH speakers.  DI boxes also typically reduce the amplitude of signals by a factor of 10.
PS. DVDdoug is correct.  The open circuit output from a guitar can be several volts.
  • Last Edit: 23 April, 2012, 04:48:29 PM by RobWansbeck
Hi all,
In an ideal world:
Could you be more specific (make, model) about the "basic guitar amplifier"?
Usually, one uses a mixer to feed one amplifier from multiple sources.
Here's an example:
Mixer for feedbug more than one source through an amplifier
