Topic: [TOS #5] From: Massive problem with fb2k 1.1.11 (93538) (Read 358 times) previous topic - next topic
  • @omic
I would rather chop my balls off and eat them myself.
Don´t be so drastic, because it wouldn´t be helpful to your problem  ..... sorry, but i can´t help you but....
I have also a big problem with ASIO (and WASAPI)
It won´t run  .....once i put the ASIO-out driver in the "Components" folder, foobar don´t start and shows window that some source is damaged.
Removing the driver, foobar runs normal
asio4all works but w/o bitperfect
Then i downloaded the WASAPI driver for foobar.... same procedure and foobar started but does not play (it produce only a frequency-part of the chosen sound track
Hardware is Acer Laptop, USB-conection to audiolab 8200CD (dac)
System is Win 7
