Topic: AAC True VBR vs. VBR? (Read 10204 times) previous topic - next topic
  • Dataz
I'm using Mac and I want the best quality available when using AAC @320 kbps.
Should I use XLD's True VBR or iTunes' VBR?
Help!
/Thanks!
  • Last Edit: 20 April, 2012, 07:15:35 AM by Dataz
  • Ouroboros
320 kbit/s is CBR, not VBR.
So, which do you want - 320 kbit/s or VBR?
  • IgorC
AAC is not MP3.
AAC can go higher than 320 kbps and Apple encoder has 320-350 kbps VBR setting.
There is no point to go higher than 256 kbps VBR for AAC. It's transparent.
  • Ouroboros
Yes, all of that is true, but 320-350 kbit/s VBR is just that - VBR. The OP asked about 320 kbit/s, which is a defined bit rate, hence CBR.
  • IgorC
OP talks about two different VBR modes.  He doesn't say anything about CBR.
  • Last Edit: 20 April, 2012, 10:51:51 AM by IgorC
  • Ouroboros
Perhaps requoting the OP might refresh your memory.....
That's a fixed bit rate, hence CBR. He then goes on to ask about which VBR codec to use, and that's a contradiction (CBR=/=VBR), hence I asked him which he meant - 320 CBR, or VBR.
  • IgorC
The point is that Apple AAC encoder has constrained VBR setting  like iTunes' VBR 320 kbps.
OP asks for this actually.
  • Ouroboros
Yes, I know that Apple AAC and iTunes have a constrained VBR mode, but the OP didn't ask about that at all. That may be what he meant, and I had guessed that might be what he meant, but I was trying to get him to be clearer about what he wants before we start giving him incorrect advice.
  • pururin
IMHO, Just forget about that debate.
To the point op asking, I'd say true VBR at around 256 kbps. Actual Bit rate will go even higher when needed, it's very flexible.
IMO 192 kbps is already great.
  • Last Edit: 27 April, 2012, 03:08:40 PM by pururin
