Topic: help with sending songs to mp3 player (Read 2552 times) previous topic - next topic
I recently converted to foobar and find it an amazing program which i can't believe i didn't know about it before.
One thing i have not worked out how to do is to transfer a playlist created in foobar to my mp3 player.
Previously (using windows media player) i could just drag the playlist to the player and sync which would put all the songs on the player and the playlist ready to use in the player. Is there a way of doing this with foobar?
I have a Creative ZEN X-Fi player.
I have searched the forums but could not find a component or details of how to do this so any guidance would be appreciated.
  • Hengest
As far as I know, a lot of those devices use media transfer protocol (MTP) to communicate with the computer. In this case, there isn't really a way of using foobar2000 to transfer music across. Of course, you can see if I'm wrong by finding out whether or not the device has a drive letter in Windows Explorer. If it does, then you'll be in luck.
"Lifting Shadows Off a Dream"
i can connect and see it as a drive and i can manually copy from my music folder to the device. However i want to be able to copy foobar playlists across and have it automatically take over the songs and the playlist - is this possible?
  • tpijag
Can not say I understand this, but the following does have the ability to send a playlist worth of various files to your player and then allow you to create and send a playlist that will use the appropriate drive letter and directory structure to work on your player.
Link to old component foo_SendToDevice
EDIT:If you decide to use this, the context menu item is a bit obscure. By default it will only be available via shift+rt click and it will be located under Legacy Commands. It will be titled Select.... You can get it to show via a simple rt click context menu by ticking it in the context menu preferences. It will, however, remain under legacy commands.
  • Last Edit: 20 April, 2012, 04:30:37 PM by tpijag
  • bernhold
Has this been changed in newer foobar versions? Because for me, it works just fine. I can drag files from the playlist to my mp3 player drive letter.
