Topic: The detail of OFL (Original File Length) (Read 2561 times) previous topic - next topic
  • urax
I'm looking for the detail of OFL(Original File Length).
For example,  I'm looking for the following info
- Data size of OFL
- Data syntax of OFL
- How should the decoder use those data?
I purchased the AES paper of OFL.
http://www.aes.org/e-lib/browse.cfm?elib=12531
Could you tell me a little more about OFL?
  • saratoga
For mp3, mp3pro, both?
  • urax
Thanks for your comments.
And I'm sorry my reply is late.
If possible, I want to know both mp3 and mp3pro.
At least, I want to know mp3.
  • AndyH-ha
Does
decoded audio signals are also typically no longer time-aligned with the original signals
mean that the time between events in the audio stream (say between one cymbal clash and the next) are a different duration than the original audio from which the mp3 was made? If so, this would be a form of jitter, no?
  • mixminus1
That would be some pretty serious jitter!
No, given the title ("Original File Length"), it appears to be referring to the encoder delay and padding that's added to each encoded MP3 file, and how to accurately remove it upon decoding and playback.
  • urax
Could I confirm the OFL?
I think OFL is meta data and has the syntax of the specification.
Does OFL have common syntax?
Is it just a concept?
