Topic: Can not deal with big archive files (Read 1059 times) previous topic - next topic
  • Excalibur
In fact, the problem is my fb2k can not open most of files(in this situation, flac/ape/wav/tak etc) in zip/rar if its original size is more than 300,000,000 bytes(I can not tell you the exact number but it is close). Some could play, but MOST of them can not(I have plenty of example for you to test if you want).
If there is a cue that can describe it, fb2k will ignore the cue sheet. I put them into zip files separately, and flac.zip doesn't work while cue.zip works really nice(although there is nothing for it to play, fb2k shows correct information).
A flac+cue.zip won't show any useful information but:
Unable to open item for playback (Unsupported file format):
"E:\Music\[EAC] [100730] GWAVE 2009 2nd Ace (Ver.tak).rar"
Ok, it is tak. But the problem is still exist.
Another problem is if I open a flac+cue.zip, the playlist will have both of them. That's really annoying so I go to ShellIntergration>ExcludeFileTypes and add "*.APE;*.FLAC;*.TTA;*.WV;*.TAK;*.WAV". But Zip Reader still tries to find embedded cue in BIG flac and in booklet(JPG/PNG/PNG).
Really a waste of time.
Sorry for my poor English. Here are some of my system information:
Windows server 2003 Enterprise Edition R2 SP2 Simplified Chinese
NT 5.2 (Build 3790)
Core (2012-02-04 13:05:48 UTC)
    foobar2000 core 1.1.11
foo_AdvancedControls.dll (2012-02-11 21:58:32 UTC)
    Foobar2000 Advanced Controls 0.6.7.4
foo_albumlist.dll (2012-02-04 13:04:12 UTC)
    Album List 4.5
foo_benchmark.dll (2012-02-11 21:57:29 UTC)
    Decoding Speed Test 1.1
foo_cdda.dll (2012-02-04 13:03:52 UTC)
    CD Audio Decoder 3.0
foo_converter.dll (2012-02-04 13:04:00 UTC)
    Converter 1.5
foo_dsp_std.dll (2012-02-04 13:04:14 UTC)
    Standard DSP Array 1.0
foo_exvar.dll (2008-11-19 06:16:54 UTC)
    扩展变量 0.3.1
foo_fileops.dll (2009-06-11 02:14:30 UTC)
    文件操作 2.1.2
foo_freedb2.dll (2012-02-04 13:03:02 UTC)
    freedb Tagger 0.6.4
foo_input_dts.dll (2010-09-09 06:42:50 UTC)
    DTS 解码器 0.3.0
foo_input_monkey.dll (2011-04-20 16:06:50 UTC)
    Monkey's Audio 解码器 2.1.5
foo_input_std.dll (2012-02-04 13:05:10 UTC)
    Standard Input Array 1.0
foo_input_tak.dll (2010-09-09 08:26:44 UTC)
    TAK 解码器 0.4.4
foo_input_tta.dll (2010-12-27 01:14:18 UTC)
    TTA 解码器 3.2
foo_playcount.dll (2011-08-22 06:14:40 UTC)
    播放统计信息 3.0.2
foo_rgscan.dll (2012-02-04 13:03:48 UTC)
    ReplayGain Scanner 2.1.2
foo_ui_columns.dll (2009-07-14 12:14:41 UTC)
    分栏用户界面 0.3.7.8
foo_ui_std.dll (2012-02-04 13:04:08 UTC)
    Default User Interface 0.9.5
foo_uie_albumlist.dll (2009-06-15 05:58:24 UTC)
    专辑列表面板 0.3.5
foo_uie_elplaylist.dll (2009-06-18 04:00:40 UTC)
    ELPlaylist 0.6.5.3.3(beta)
foo_uie_lyrics.dll (2008-12-12 09:40:18 UTC)
    歌词秀面板 0.3.3.9 [Dec 12 2008 - 17:39:59]
foo_uie_lyrics3.dll (2012-03-20 23:47:20 UTC)
    Lyric Show Panel 3 0.2.3
foo_uie_panel_splitter.dll (2009-06-15 07:38:11 UTC)
    面板栈分离器 0.3.8(alpha)
foo_uie_wsh_panel_mod.dll (2009-07-15 14:58:01 UTC)
    WSH 面板增强版 1.1.9
foo_unpack.dll (2012-02-04 13:03:26 UTC)
    ZIP/GZIP/RAR Reader 1.6
foo_unpack_7z.dll (2012-02-11 21:33:36 UTC)
    7-Zip reader 1.8
foo_w7shell.dll (2010-01-17 10:09:20 UTC)
    Windows 7 integration 0.2.9.1
  • kode54
  • Administrator
Files from archives are always unpacked completely to memory, so if the file is too large to fit into memory, it won't work. If the archive contains more archives, those archives will be unpacked to memory as well.
