Topic: Playing back a 96 KHz file produces lots of noise (Read 1507 times) previous topic - next topic
  • Dario
Hello there,
I just noticed that if I were to play a file with a sampling rate of 96 KHz (or higher), my speakers would produce a lot of noise.
It happens with all files I've tried, regardless of whether they were originally stored in 96 KHz or upsampled from 44.1/48. The bit depth makes no difference either. I'm using a (rather old) motherboard with an integrated sound card and Realtek HD output and a pair of cheap PC speakers.
On the other hand, if I were to put up a DSP that would resample the output to 44.1/48 KHz, everything would sound just fine.
Do you guys have any idea what could be causing this? It's really annoying.
  • DVDdoug
Bad drivers?
If you've already checked for updated drivers, maybe you need a new soundcard.  You can get a cheap one for under $10 USD.    I bought a cheap USB soundcard (for maybe $20) just for such "experimental purposes".
(Speakers should have nothing to do with it, since the analog sound going to the speakers is analog and doesn't have a sample rate.)
  • Last Edit: 03 April, 2012, 06:31:46 PM by DVDdoug
  • Kohlrabi
  • Global Moderator
I don't think the possibility of playing ultrasonics warrants getting a new soundcard. Just stick to 44.1/48 kHz sampling rate, probably your speakers won't play back ultrasonics properly, anyway.
  • db1989
  • Global Moderator
Perhaps a silly question: Does your hardware support 96 kHz?
What is the purpose of doing that?
  • Wombat
I am no expert but if you have Windows 7 running there was a hotfix lately that fixes some linear interpolation for playback. Maybe this is the case with your Realtek?
There is a thread here somewhere about this but i didn´t find it and don´t remember its title.
  • Dario
It was the drivers. Silly enough, I thought I had updated them three weeks ago. Thanks a million guys!
I'm running WinXP, but seems like updating the drivers fixed it.
Oh, there's no purpose. I was just trying to make sure it wasn't caused by the high-res files themselves (since the amount of such files I have is really low, due to the fact that I see no point in having them and the kind of music I listen to isn't really available as high-res downloads).
I know, I know. I tried ABX-ing these high-res downloads against "regular" ones (from CDs), and couldn't spot a difference.
