Topic: Error splitting FLAC w/cue—Unable to open file for writing (not found) (Read 2644 times) previous topic - next topic
  • cmg
Hi
Foobar2000, v.1.1.11
When splliting a FLAC file, I get this message (different text) for some files: "Source: "D:\..........\T. Pinnock & The English Concert - J. S. Bach, Brandenburgische Konzerte 1-2-3\The English Concert & Trevor Pinnock - Brandenburgische Konzerte 1-2-3.cue" / index: 1
  Unable to open file for writing (Object not found) : "D:\Program Files\JDownloader\Downloads\T. Pinnock & The English Concert - J. S. Bach, Brandenburgische Konzerte 1-2-3\The English Concert & Trevor Pinnock - Brandenburgische Konzerte 1-2-3\01. Concerto No. 1, BWV 1046 in F major - 1 ohne Satzbezeichnung (no tempo indica...).flac"
  Conversion failed: Object not found"
The cue is:
REM GENRE Classical
REM DATE 1982
REM DISCID 800A2F0A
REM COMMENT "ExactAudioCopy v1.0b2"
CATALOG 0028941050021
PERFORMER "The English Concert & Trevor Pinnock"
TITLE "Brandenburgische Konzerte 1-2-3"
FILE "The English Concert & Trevor Pinnock - Brandenburgische Konzerte 1-2-3.flac" WAVE
  TRACK 01 AUDIO
   TITLE "Concerto No. 1, BWV 1046 in F major - 1 ohne Satzbezeichnung (no tempo indica...)"
   ISRC DEF058200360
   INDEX 00 00:00:00
   INDEX 01 00:00:32
  TRACK 02 AUDIO
   TITLE "Concerto No. 1, BWV 1046 in F major - 2 Adagio"
   ISRC DEF058200360
   INDEX 00 04:07:27
   INDEX 01 04:11:27
  TRACK 03 AUDIO
   TITLE "Concerto No. 1, BWV 1046 in F major - 3 Allegro"
   ISRC DEF058200360
   INDEX 00 08:24:38
   INDEX 01 08:24:60
  TRACK 04 AUDIO
   TITLE "Concerto No. 1, BWV 1046 in F major - 4 Menuetto - Trio I - Polacca - Trio II"
   ISRC DEF058200360
   INDEX 00 12:30:45
   INDEX 01 12:34:25
  TRACK 05 AUDIO
   TITLE "Concerto No. 2, BWV 1047 in F major - 1 ohne Satzbezeichnung (no tempo indica...)"
   ISRC DEF058200370
   INDEX 00 19:59:45
   INDEX 01 20:05:17
  TRACK 06 AUDIO
   TITLE "Concerto No. 2, BWV 1047 in F major - 2 Andante"
   ISRC DEF058200370
   INDEX 00 25:19:05
   INDEX 01 25:23:47
  TRACK 07 AUDIO
   TITLE "Concerto No. 2, BWV 1047 in F major - 3 Allegro assai"
   ISRC DEF058200370
   INDEX 00 29:15:68
   INDEX 01 29:16:27
  TRACK 08 AUDIO
   TITLE "Concerto No. 3, BWV 1048 in G major - 1 ohne Satzbezeichnung (no tempo indica...)"
   ISRC DEF058200410
   INDEX 00 32:19:35
   INDEX 01 32:23:47
  TRACK 09 AUDIO
   TITLE "Concerto No. 3, BWV 1048 in G major - 2 Adagio"
   ISRC DEF058200410
   INDEX 00 38:08:48
   INDEX 01 38:08:50
  TRACK 10 AUDIO
   TITLE "Concerto No. 3, BWV 1048 in G major - 3 Allegro"
   ISRC DEF058200410
   INDEX 00 38:41:28
   INDEX 01 38:42:20
What's wrong?
Thanks for any help
Regards
cmg
  • Last Edit: 31 March, 2012, 05:22:00 PM by db1989
  • Andreasvb
Does not compute.
Try rename or change so it goes to correct file.
  • lvqcl
is 276 characters long. Many programs cannot read/write such files (with path+name longer than 256 chars).
  • mjb2006
To regain access to the files whose paths are too long, you could do any of the following:
  • shorten one (or more) of the folder names
  • temporarily copy everything to e.g. C:\ or C:\temp
  • use the 'subst' command or the Visual Subst front-end to map a drive letter to C:\Program Files\JDownloader\Downloads
  • Last Edit: 31 March, 2012, 03:08:24 PM by mjb2006
  • cmg
Hi
Thanks to all.
The problem was due to too long titles.
Now everything is OK.
Regards
cmg
