Topic: When using media server to stream to PS3, I get drop-outs every 6 sec (Read 3032 times) previous topic - next topic
  • jorgen68
When streaming(wireless) music to my ps3 i have audiodropouts every 6seconds.I also have dropouts when i use Ps3 media server but it's much worse with foobar.I have a hardline between my pc and my router(dsl-2740B)and wireless to my ps3 and i have xp professional on my pc.
  • kode54
  • Administrator
That is probably because the PS3 client profile dictates that all files will be sent over the network as raw PCM, which requires a lot of bandwidth, but nothing that a wired or even possibly wireless network shouldn't be able to handle. For instance, CD quality (44100Hz 16 bit stereo) would eat up almost 1.5Mbps of bandwidth.
  • Last Edit: 30 March, 2012, 03:48:23 AM by kode54
I've noticed the same problem when i was streaming music wirelessly from FB2k to our PS3. Our router was less than 1m away and it would dropout every 30 seconds or so. I have hard wired the PS3 now and no more drop outs.
  • jorgen68
i tried with a wire and it didn't help.i am trying to locate the log file but i can't find it.
  • Last Edit: 01 April, 2012, 03:22:46 AM by jorgen68
  • jorgen68
http://www.thesycon.de/deu/latency_check.shtml  i did a latency check and it looked good so thats not the problem and i did ping tests for the computer and router and it looked good also
  • jorgen68
here is the log
foo_upnp: 34.219: FbMediaServer::ProcessHttpRequest(330)/4576: INFO: received LAN request: [url=http://192.168.1.2:56923/ContentDirectory/22e9c3ad-f779-13e9-e184-76f6f691b26b/control.xml]http://192.168.1.2:56923/ContentDirectory/...26b/control.xml[/url] (User-Agent: UPnP/1.0 DLNADOC/1.50)
foo_upnp: 34.219: FbMediaServer::OnAction(261)/4576: INFO: received action 'GetSystemUpdateID', args = {  }
foo_upnp: 34.219: FbMediaServer::OnAction(284)/4576: INFO: action 'GetSystemUpdateID' response: args = { Id=0 }
foo_upnp: 34.641: FbMediaServer::ProcessHttpRequest(330)/3180: INFO: received LAN request: [url=http://192.168.1.2:56923/ContentDirectory/22e9c3ad-f779-13e9-e184-76f6f691b26b/control.xml]http://192.168.1.2:56923/ContentDirectory/...26b/control.xml[/url] (User-Agent: UPnP/1.0 DLNADOC/1.50)
foo_upnp: 34.641: FbMediaServer::OnAction(261)/3180: INFO: received action 'Browse', args = { ObjectID=0/0, BrowseFlag=BrowseMetadata, Filter=@id,upnp:class,res,res@protocolInfo,res@av:authenticationUri,res@size,dc:title,upnp:albumArtU
RI,res@dlna:ifoFileURI,res@protection,res@bitrate,res@duration,res@sampleFrequency,res@bitsPerSample
res@nrAudioChannels,res@resolution,res@colorDepth,dc:date,av:dateTime,upnp:artist,upnp:album,upnp:ge
n
re,dc:contributer,upnp:storageFree,upnp:storageUsed,upnp:originalTrackNumber,dc:publisher,dc:languag
e
,dc:region,dc:description,upnp:toc,@childCount,upnp:albumArtURI@dlna:profileID,res@dlna:cleartextSiz
e
, StartingIndex=0, RequestedCount=1, SortCriteria= }
foo_upnp: 34.641: PLT_MediaServer::OnBrowse(380)/3180: INFO: Received BrowseMetadata from 192.168.1.3 for id = 0/0 with filter = @id,upnp:class,res,res@protocolInfo,res@av:authenticationUri,res@size,dc:title,upnp:albumArtURI,res@
dlna:ifoFileURI,res@protection,res@bitrate,res@duration,res@sampleFrequency,res@bitsPerSample,res@nr
A
udioChannels,res@resolution,res@colorDepth,dc:date,av:dateTime,upnp:artist,upnp:album,upnp:genre,dc:
c
ontributer,upnp:storageFree,upnp:storageUsed,upnp:originalTrackNumber,dc:publisher,dc:language,dc:re
g
ion,dc:description,upnp:toc,@childCount,upnp:albumArtURI@dlna:profileID,res@dlna:cleartextSize, start = 0, count = 1
foo_upnp: 34.641: FbMediaServer::OnAction(284)/3180: INFO: action 'Browse' response: args = { ObjectID=0/0, BrowseFlag=BrowseMetadata, Filter=@id,upnp:class,res,res@protocolInfo,res@av:authenticationUri,res@size,dc:title,upnp:albumArtU
n
e
e
, StartingIndex=0, RequestedCount=1, SortCriteria=, NumberReturned=1, TotalMatches=1, UpdateID=0 }
foo_upnp: 34.844: FbMediaServer::ProcessHttpRequest(330)/4840: INFO: received LAN request: [url=http://192.168.1.2:56923/ContentDirectory/22e9c3ad-f779-13e9-e184-76f6f691b26b/control.xml]http://192.168.1.2:56923/ContentDirectory/...26b/control.xml[/url] (User-Agent: UPnP/1.0 DLNADOC/1.50)
foo_upnp: 34.844: FbMediaServer::OnAction(261)/4840: INFO: received action 'GetSystemUpdateID', args = {  }
foo_upnp: 34.844: FbMediaServer::OnAction(284)/4840: INFO: action 'GetSystemUpdateID' response: args = { Id=0 }
foo_upnp: 35.235: FbMediaServer::ProcessHttpRequest(330)/3608: INFO: received LAN request: [url=http://192.168.1.2:56923/ContentDirectory/22e9c3ad-f779-13e9-e184-76f6f691b26b/control.xml]http://192.168.1.2:56923/ContentDirectory/...26b/control.xml[/url] (User-Agent: UPnP/1.0 DLNADOC/1.50)
foo_upnp: 35.235: FbMediaServer::OnAction(261)/3608: INFO: received action 'Browse', args = { ObjectID=0/0/0, BrowseFlag=BrowseMetadata, Filter=@id,upnp:class,res,res@protocolInfo,res@av:authenticationUri,res@size,dc:title,upnp:albumArtU
n
e
e
foo_upnp: 35.235: PLT_MediaServer::OnBrowse(380)/3608: INFO: Received BrowseMetadata from 192.168.1.3 for id = 0/0/0 with filter = @id,upnp:class,res,res@protocolInfo,res@av:authenticationUri,res@size,dc:title,upnp:albumArtURI,res@
A
c
g
foo_upnp: 35.235: FbMediaServer::OnAction(284)/3608: INFO: action 'Browse' response: args = { ObjectID=0/0/0, BrowseFlag=BrowseMetadata, Filter=@id,upnp:class,res,res@protocolInfo,res@av:authenticationUri,res@size,dc:title,upnp:albumArtU
n
e
e
foo_upnp: 35.641: FbMediaServer::ProcessHttpRequest(330)/5580: INFO: received LAN request: [url=http://192.168.1.2:56923/ContentDirectory/22e9c3ad-f779-13e9-e184-76f6f691b26b/control.xml]http://192.168.1.2:56923/ContentDirectory/...26b/control.xml[/url] (User-Agent: UPnP/1.0 DLNADOC/1.50)
foo_upnp: 35.641: FbMediaServer::OnAction(261)/5580: INFO: received action 'GetSystemUpdateID', args = {  }
foo_upnp: 35.641: FbMediaServer::OnAction(284)/5580: INFO: action 'GetSystemUpdateID' response: args = { Id=0 }
foo_upnp: 36.032: FbMediaServer::ProcessHttpRequest(330)/2044: INFO: received LAN request: [url=http://192.168.1.2:56923/ContentDirectory/22e9c3ad-f779-13e9-e184-76f6f691b26b/control.xml]http://192.168.1.2:56923/ContentDirectory/...26b/control.xml[/url] (User-Agent: UPnP/1.0 DLNADOC/1.50)
foo_upnp: 36.032: FbMediaServer::OnAction(261)/2044: INFO: received action 'Browse', args = { ObjectID=0/0, BrowseFlag=BrowseMetadata, Filter=@id,upnp:class,res,res@protocolInfo,res@av:authenticationUri,res@size,dc:title,upnp:albumArtU
n
e
e
foo_upnp: 36.032: PLT_MediaServer::OnBrowse(380)/2044: INFO: Received BrowseMetadata from 192.168.1.3 for id = 0/0 with filter = @id,upnp:class,res,res@protocolInfo,res@av:authenticationUri,res@size,dc:title,upnp:albumArtURI,res@
A
c
g
foo_upnp: 36.032: FbMediaServer::OnAction(284)/2044: INFO: action 'Browse' response: args = { ObjectID=0/0, BrowseFlag=BrowseMetadata, Filter=@id,upnp:class,res,res@protocolInfo,res@av:authenticationUri,res@size,dc:title,upnp:albumArtU
n
e
e
foo_upnp: 36.438: FbMediaServer::ProcessHttpRequest(330)/5480: INFO: received LAN request: [url=http://192.168.1.2:56923/ContentDirectory/22e9c3ad-f779-13e9-e184-76f6f691b26b/control.xml]http://192.168.1.2:56923/ContentDirectory/...26b/control.xml[/url] (User-Agent: UPnP/1.0 DLNADOC/1.50)
foo_upnp: 36.438: FbMediaServer::OnAction(261)/5480: INFO: received action 'GetSystemUpdateID', args = {  }
foo_upnp: 36.438: FbMediaServer::OnAction(284)/5480: INFO: action 'GetSystemUpdateID' response: args = { Id=0 }
foo_upnp: 36.547: FbMediaServer::ProcessHttpRequest(330)/2136: INFO: received LAN request: [url=http://192.168.1.2:56923/content/eedcf0da828d51e6676fba6d5ad778cf.l16?profile_id=4&convert=lpcm]http://192.168.1.2:56923/content/eedcf0da8...mp;convert=lpcm[/url] (User-Agent: PLAYSTATION 3)
foo_upnp: 36.547: PLT_HttpHelper::ToLog(441)/2136: INFO:
GET /content/eedcf0da828d51e6676fba6d5ad778cf.l16?profile_id=4&convert=lpcm HTTP/1.1
Host: 192.168.1.2:56923
Connection: Keep-Alive
Accept-Encoding: identity
transferMode.dlna.org: Streaming
X-AV-Client-Info: av=5.0; cn="Sony Computer Entertainment"; mn="PLAYSTATION 3"; mv="1.0";
Range: bytes=0-
foo_upnp: 36.547: upnp_server_conf::get_profile(740)/2136: INFO: using profile 'PlayStation 3', matching header (User-Agent:PLAYSTATION 3)
foo_upnp: opened 'file://E:\musik\Bruce Springsteen\Wrecking Ball\Bruce Springsteen - 01. We Take Care Of Our Own.flac' for streaming, profile: PlayStation 3, LPCM / 44100 Hz / 16 bits / 2 channels, replaygain: on, DSP chain: off
foo_upnp: 36.844: FbMediaServer::ProcessHttpRequest(330)/1064: INFO: received LAN request: [url=http://192.168.1.2:56923/ContentDirectory/22e9c3ad-f779-13e9-e184-76f6f691b26b/control.xml]http://192.168.1.2:56923/ContentDirectory/...26b/control.xml[/url] (User-Agent: UPnP/1.0 DLNADOC/1.50)
foo_upnp: 36.844: FbMediaServer::OnAction(261)/1064: INFO: received action 'Browse', args = { ObjectID=0/0/0, BrowseFlag=BrowseMetadata, Filter=@id,upnp:class,res,res@protocolInfo,res@av:authenticationUri,res@size,dc:title,upnp:albumArtU
n
e
e
foo_upnp: 36.844: PLT_MediaServer::OnBrowse(380)/1064: INFO: Received BrowseMetadata from 192.168.1.3 for id = 0/0/0 with filter = @id,upnp:class,res,res@protocolInfo,res@av:authenticationUri,res@size,dc:title,upnp:albumArtURI,res@
A
c
g
foo_upnp: 36.844: FbMediaServer::OnAction(284)/1064: INFO: action 'Browse' response: args = { ObjectID=0/0/0, BrowseFlag=BrowseMetadata, Filter=@id,upnp:class,res,res@protocolInfo,res@av:authenticationUri,res@size,dc:title,upnp:albumArtU
n
e
e
foo_upnp: 37.250: FbMediaServer::ProcessHttpRequest(330)/1932: INFO: received LAN request: [url=http://192.168.1.2:56923/ContentDirectory/22e9c3ad-f779-13e9-e184-76f6f691b26b/control.xml]http://192.168.1.2:56923/ContentDirectory/...26b/control.xml[/url] (User-Agent: UPnP/1.0 DLNADOC/1.50)
foo_upnp: 37.250: FbMediaServer::OnAction(261)/1932: INFO: received action 'GetSystemUpdateID', args = {  }
foo_upnp: 37.250: FbMediaServer::OnAction(284)/1932: INFO: action 'GetSystemUpdateID' response: args = { Id=0 }
foo_upnp: 37.641: FbMediaServer::ProcessHttpRequest(330)/6044: INFO: received LAN request: [url=http://192.168.1.2:56923/ContentDirectory/22e9c3ad-f779-13e9-e184-76f6f691b26b/control.xml]http://192.168.1.2:56923/ContentDirectory/...26b/control.xml[/url] (User-Agent: UPnP/1.0 DLNADOC/1.50)
foo_upnp: 37.641: FbMediaServer::OnAction(261)/6044: INFO: received action 'Browse', args = { ObjectID=0/0/0, BrowseFlag=BrowseMetadata, Filter=@id,upnp:class,res,res@protocolInfo,res@av:authenticationUri,res@size,dc:title,upnp:albumArtU
n
e
e
foo_upnp: 37.641: PLT_MediaServer::OnBrowse(380)/6044: INFO: Received BrowseMetadata from 192.168.1.3 for id = 0/0/0 with filter = @id,upnp:class,res,res@protocolInfo,res@av:authenticationUri,res@size,dc:title,upnp:albumArtURI,res@
A
c
g
foo_upnp: 37.641: FbMediaServer::OnAction(284)/6044: INFO: action 'Browse' response: args = { ObjectID=0/0/0, BrowseFlag=BrowseMetadata, Filter=@id,upnp:class,res,res@protocolInfo,res@av:authenticationUri,res@size,dc:title,upnp:albumArtU
n
e
e
foo_upnp: 37.828: PLT_HttpServerSocketTask::Write(348)/2136: WARNING: NPT_CHECK failed, result=-20401 (NPT_ERROR_CONNECTION_ABORTED) [(NPT_StreamToStreamCopy( *body_stream.AsPointer(), *output_stream.AsPointer(), 0, entity->GetContentLength(), 0, abort))]
foo_upnp: 37.828: FbMediaServer::ProcessHttpRequest(330)/1328: INFO: received LAN request: [url=http://192.168.1.2:56923/content/eedcf0da828d51e6676fba6d5ad778cf.l16?profile_id=4&convert=lpcm]http://192.168.1.2:56923/content/eedcf0da8...mp;convert=lpcm[/url] (User-Agent: PLAYSTATION 3)
foo_upnp: 37.828: PLT_HttpHelper::ToLog(441)/1328: INFO:
Range: bytes=0-
foo_upnp: 37.828: upnp_server_conf::get_profile(740)/1328: INFO: using profile 'PlayStation 3', matching header (User-Agent:PLAYSTATION 3)
foo_upnp: 78.485: PLT_HttpServerSocketTask::Write(348)/1328: WARNING: NPT_CHECK failed, result=-20401 (NPT_ERROR_CONNECTION_ABORTED) [(NPT_StreamToStreamCopy( *body_stream.AsPointer(), *output_stream.AsPointer(), 0, entity->GetContentLength(), 0, abort))]
  • Last Edit: 02 April, 2012, 04:21:34 PM by db1989
  • jorgen68
Finally i've found the answer.I've found it on this page http://bubbleguuum.free.fr/foo_upnp/foo_upnp.txt  and here's ow you change it in the Ps3 http://manuals.playstation.net/document/en...tfrequency.html    just change the output frequency to 48 KHz on the Ps3.
  • Last Edit: 03 April, 2012, 10:03:31 AM by jorgen68
