Topic: Amplitude Sweep? (Read 1878 times) previous topic - next topic
  • ksr
Amplitude Sweep?
hello guys,
I am trying to generate Amplitude Sweep Signal, at a given constant frequency with the following equation
X(n) = 10^{(start_amp + Delta.k.t)/20} * Sin(2.pi.f .t) * (1<<24)
but i am not getting exact Amplitude sweep signal, can any one know whats wrong with above formula....
If there exist a better way of generating Amplitude sweep signal with a specific formula, please explain
Thanks in Advance....[/size]
  • Notat
Amplitude Sweep?
Looks like you're on the right track. What are you using for start_amp, Delta and k? What's going wrong?
  • ksr
Amplitude Sweep?
According to the test stream
start_amp = -120
stop_amp = 0
duration of sweep = 30 sec
Delta.k    = (stop_amp - start_amp)/duration of sweep  = 120/30 = 4
sampling rate = 48000
and yes bro, i am almost there, but my problem is up-to 2 digits of decimal part the amplitude values are matching with reference and after that they are differing and some( 2 or 3) values in decimal part are entirely differing.
Any thoughts ?
  • Last Edit: 20 March, 2012, 12:49:53 AM by ksr
Amplitude Sweep?
hello guys,
You might be expecting too much. The highest amplitude sample points on the waveform of a sweep naturally jump up and down because the sampling frequency does not always line up with the frequency of the generated wave at most points.
  • ksr
Amplitude Sweep?
hello guys,
Thanks bro...can you explain in detail the above concept ????
