Topic: Stop after current in taskbar icon context menu (Read 896 times) previous topic - next topic
  • Grilinctus
Hi.  Would it be possible to add the option to ‘Stop after current’ to the context menu for the taskbar icon?  I tend to run fb2k minimized most of the time. (Obviously, this is a pretty minor thing; it’d just be a little more convenient.)
  • pIv
A. If foobar not minimized:
1. Right Click Mouse on toolbar region "Buttons".
2. Select "Customize Buttons..." command.
3. In right window select command "Main/Playback/Stop after current" and push on "Add" button.
4. In left window you can reorder buttons, change icons to commands.
5. Left Click Mouse on button "OK" -> new icon for your command added to "buttons panel".
B. Foobar minimized:
1. Use "Deskband controls" plugin. With this plugin you can see "Deskband controls panel" and display on it "Stop after current" button.
  • Last Edit: 14 March, 2012, 06:03:14 AM by pIv
