Topic: foo_playcount_sql, xml-export, match entries with files (Read 628 times) previous topic - next topic
with foo_playcount_sql you can export your Playback Statistics to a XML-file. I'm programmer for PHP and would like to write a little script using this XML-File.
But the entries look like this:(
<Entry ID="166c0be2e38d7c95" Count="38" FirstPlayed="129679249500231441" LastPlayed="129748216671585111" Added="129679248782790406" />
1. Any ideas how to match the given ID to the corresponding file?
2. What kind of date type is 129679249500231441? Doesn't seem to be timestamp...
Thanks a lot!
Fulbert
  • kode54
ID is a file identifier hash generated by the database component, in this case from several tags so that entries may be file format and/or encoding independent. All of the time stamps are in Windows FILETIME units.
