Topic: Playlist scroll problem when using page up/down keys and grouping (Read 953 times) previous topic - next topic
  • DervishD
Hi all
foobar2000 v1.1.11 with default UI, Windows 7 64, no "bad" components according to the online troobleshooter.
Short description: when grouping is enabled and you scroll your playlist contents using page up or page down keys, the number of lines scrolled are not calculated properly because the additional lines introduced by the grouping are not taken into account when scrolling.
Detailed description: let's say that with your current window size you can see 10 playlist entries, then if you hit page up or page down keys, the list will scroll 10 entries up or down. If you have grouping enabled, your playlist will have additional lines due to grouping (e.g. the artist name when grouping "By artist") but the list will still scroll 10 songs when you hit page up or page down, it should scroll 10 screen lines, not 10 songs.
Hope I explained it correctly, but I can include screenshots if needed.
Raúl
  • dhromed
I have the same problem, and posted a thread quite a while ago that I can't find anymore after 45 seconds of searching, but the reception was slightly less than enthusiastic.
Fact remains, it's difficult to pagedown through a large playlist when it arbitrarily skips items based on how dense the grouping is of a given portion of playlist. I've taken to middle-dragging and/or holding down the down-arrow key, but a properly working pageup/down would be nice.
  • DervishD
Hi dhromed
Thanks for confirming, I was thinking that only my wife and me had the problem.
I couldn't find your thread, either, I searched the forum and Google for a couple of hours trying to find similar reports to no avail.
  • dhromed
It's by design. Foobar uses the selected item as a reference point, instead of what's in the playlist's viewport.
  • DervishD
Thanks for the explanation
