Topic: Different track length after converting to ogg (Read 3710 times) previous topic - next topic
  • Pete7874
Sometimes when I convert from another lossy format such as MP3 to ogg, the resulting track length is different.  For example, I converted a 256 kbps CBR MP3 with a duration of 1h 59m 47s to q2 OGG using aoTuV [20110424].  The resulting ogg file has a duration of 1h 59m 39s.  Where did the 8 seconds disappear?
I realize it is not a huge difference.  I was just curious what causes such things to happen?
  • Kohlrabi
  • Global Moderator
How did you convert your files? "Losing" 8 seconds sounds like a serious bug in the converter.
  • Pete7874
Using Foobar2000 1.1.11.
  • Pete7874
OK, I think it's a problem with Foobar itself.  Foobar is reporting that the source MP3 file's duration is 1h 59m 47s, but when I actually play that track, the track stops playing at 1h 59m 39s.  Windows 7 is also reporting that the track length is only 1h 59m 39s.  Not quite sure why Foobar is misreporting the length of the MP3...
  • tpijag
select file>context menu>utilities>Fix vbr header
  • Last Edit: 25 February, 2012, 12:40:23 PM by tpijag
  • lvqcl
My guess: this MP3 file doesn't have a header (with info about its exact duration), so "1h 59m 47s" is just an estimate.
You can select mp3 file -> right click-> Utilities -> Fix VBR MP3 header.
  • Pete7874
Thank you!
