Topic: No shuffle / Playback Next or Random repeats the song (Read 1227 times) previous topic - next topic
  • deshardiii
Apologies if this has been posted, but i can not find a thread bout it. So, my problem is i can t get the Random or Shuffle funtion at the playback to work. Take a look yourself, it s set to Shuffle but it does only repeat every song i "sent to current list" (double click plays the song intermediatly) nd that song is on repeat til i change it.
Even when i click the button above in the topmenu, Playback (Next or Random) it just starts the same song from the beginning.
Does anyone ave an idea how to solve this, i don t want to go with Mediaplayer coz of this.
  • db1989
  • Global Moderator
Wow, we’re skating close to TOS #10 with this one.
  • Andreasvb
Works as expected.
It plays what's in the playlist. Since you only send one song there, it will play that one, only.
You don't use any playlist in your layout, add one and you'll see what I mean.
For a start you can try some built-in layouts:
View > Layout > Quick setup.
  • deshardiii
Works as expected.
Thank you very much, i was susspecting that. Solved now by installing Playlist Manager thanx.
