Topic: A bug of neroaactag.exe? (Read 1855 times) previous topic - next topic
  • quadamage
Hi there, I have troubles in  setting tag value containing quotation marks
C:\>neroaactag test.m4a -meta:title="Test Title"
Processing file: "test.m4a"
Updating MP4 file...
File updated successfully.
It just worked fine to set the title value to Test Title
C:\>neroaactag test.m4a -meta:title=""Test Title""
  Invalid/unknown command: Title
It failed when I tried to set the title value to "Test Title"
Can anyone tell me what's wrong with the command or is this just a bug of neroaactag.exe?
Thank you in advance.
  • lvqcl
  • Developer
\" works:
neroaactag test.m4a -meta:title="\"Test Title\""
  • nu774
  • Developer
Here is the MSVC runtime command line arguments (argv) parsing rule:
Parsing C++ Command-Line Arguments
However, note that it is not handled not by OS layer or shell (cmd.exe), but C runtime implementation specific, which can vary with compilers. In MSVC case, functions such as __getmainargs() or __wgetmainargs() are internally used.
cmd.exe also has it's own parsing rules. Double quote in cmd.exe has also special meaning for cmd.exe, therefore it can be confusing.
Escape character of cmd.exe is ^ (circumflex).
