Topic: Decode AAC samples (Read 3302 times) previous topic - next topic
  • dsh
Decode AAC samples
I trying decode raw AAC frames with my ADTS header (20050Hz, stereo), if I use internal decoder, decoder "run" method raise exception. If I play file with raw frames + my ADTS headers,  foobar play file corectly. I don't understand why foobar decoder reject my frames.
  • kode54
Decode AAC samples
As far as I know, the internal decoder does not support raw AAC frames, only ADTS.
  • dsh
Decode AAC samples
Raw AAC frames (44100Hz, stereo) internal decoder decode correctly, but each AAC frame stored in file must always have ADTS header. What decoder library is used in internal decoder?
  • kode54
Decode AAC samples
FAAD2.
  • dsh
Decode AAC samples
Is it possible implement by Foobar devs support RAW AAC 22050Hz? (RAW AAC 44100Hz works fine)  FAAD2 decode raw stream (RAW AAC 22050Hz) correctly, but I would like use internal decoder against external libaries.
  • kode54
Decode AAC samples
Maybe if you post some test streams?
  • dsh
Decode AAC samples
Samples:
Files with r1 extensions contains raw AAC frames with frame size.
Samples
Frames:
int32 - frame size
byte[size] - frame data  RAW ACC
