Topic: Problem Showing Mp3 Lyrics (Read 891 times) previous topic - next topic
So I have just recently switched over to foobar and I have trouble getting the lyrics to show only for my mp3's, my flac's work fine. I am also having trouble moving lyrics with any kind of audio file to my ipod using foobar. Also it might be important to know that I am using Columns UI.
  • db1989
  • Global Moderator
Which component do you use to display lyrics?
Which tag field do you use to store lyrics in MP3 files?
Which do you use in FLAC files?
Are these the same?
If they are different, which is your lyric-displaying component configured to use?
And so on.
This thread will be moved out of Support if your issue turns out not to be a genuine problem with the core application or an official plugin, in line with the rules of said subforum.
Are these the same?
And so on.
I am not sure what component I use to display the lyrics, sorry. I use mp3tag pro to write the lyrics to both my mp3's and flac's, in foobar it comes up as "<unsynced lyrics>". Sorry for posting in wrong area too, I wasn't sure exactly where to post this.
