Topic: Recommended program for FLAC tagging ? (Read 12101 times) previous topic - next topic
  • Xrcr9709
Hello,
a)What programs are recommended to tag existing FLAC files ?
b)And whether it's recommended or not, is WinAmp ok to tag files ? (I mean no compatibility problems or anything.)
Thank you.
  • db1989
  • Global Moderator
What kind of program do you want? GUI- or commandline-based?
If the former, I believe many users here would recommend MP3tag. Other programs that support Vorbis Comment tags include foobar2000.
If the latter, there is an offical tool: metaflac
  • Last Edit: 21 February, 2012, 07:15:43 AM by db1989
  • Xrcr9709
A GUI, at least for now.
Thank you.
  • Xrcr9709
What's a little bit disappointing about MP3tag is that it doesn't seem to support multiline 'comments' field.
Any comments about this ? Should I avoid multiline comments ?
  • Ouroboros
Maybe we mean different things, but I have lots of comment fields with multiple lines, and MP3Tag works with them quite happily. Press control-enter at the end of the line to create a new line.
It only shows up properly (on my installation) when I view it under extended tags (right click - extended tags - double click on "comment"), but it definitely works, and when I view the comment in Foobar it appears on multiple lines.
  • mixminus1
I've been using MP3Tag for years - and yes, I have read through most of the documentation  - and *still* I'm learning new things about it - thanks!
  • yourlord
I use kid3 for a gui.. for command line it's metaflac
  • Nessuno
Give a look to an easy, powerfull and cross platform one: Ex Falso http://en.wikipedia.org/wiki/Ex_Falso_(software)
... I live by long distance.
