Topic: Update failure (Read 1535 times) previous topic - next topic
  • reselty
Update failure
Hi
My foobar2000 v1.1.7
do not update anymore
Update check failure: DNS error : could not resolve "http"
Could not check for updates: DNS error : could not resolve "http"
Online troubleshooter failure: DNS error : could not resolve "http"
what can I do?
  • Andreasvb
Update failure
What's your DNS settings?
Try change to Google's 8.8.8.8
http://windows.microsoft.com/en-US/windows...TCP-IP-settings
  • reselty
Update failure
Thanks for answering , but I do not really understand - do you mean windows (xp) settings?
I didn't changed anything in it.
  • Andreasvb
Update failure
Yes, try change it then.
  • reselty
Update failure
Can only change them as Administrator.
As Administrator I started foobar without any changes > Updating no problem.
So I do not any changes on the DNS settings cause there are three different once and it is PC @ work.
And I do not understand why I should have other once on my profile..
I think there must be another problem (or not??)
  • Andreasvb
Update failure
Do you use a proxy automatic configuration script?
They are quite common at work.
  • reselty
Update failure
I have to find out first what you mean with that..but:
Theire was 3 different DNS listed. I added the 8.8.8.8 as last one.
But still no connection in my profile.
  • kode54
  • Administrator
Update failure
Check here:
  • reselty
Update failure
Check here:
Thanks - But: No change!
