Topic: playlist_incoming_item_filter progress dialog pops up everytime (Read 1713 times) previous topic - next topic
  • mitchjs
im using
playlist_incoming_item_filter_v2>()->process_locations_async()
to load a playlist (m3u8 file) with a lot of files in it, it works but.. the ugly dialog box pops up everytime, showig progress of it loading in
and im using op_flag_delay_ui
my code is as follows
// Process... calls notify when done
        static_api_ptr_t<playlist_incoming_item_filter_v2>()->process_locations_async(
                    files,
                    playlist_incoming_item_filter_v2::op_flag_delay_ui,
                    NULL,
                    core_api::get_main_window(),
                    notify);
any idea how to completly prevent that dialog?
thanks
mitch
  • mitchjs
bump!
  • foosion
  • Moderator
There is no way to completely suppress the dialog. Most probably because it is considered bad style for a component to perform a lengthy operation without giving the user a way to cancel it.
http://foosion.foobar2000.org/ - my components for foobar2000
