Topic: Rockboxed Sansa Clip+, how can I change the USB mode? (Read 5682 times) previous topic - next topic
  • Squeller
hmm, I've updated my Clip+ with Rockbox. In order to do this, I had to change it to MSC usb mode. Now it's rockboxed, but Windows7 does not detect the hardware correctly. I think I need to change it to mtp mode again (this way I'd see 2 drives as I was used to) - but how? I cannot find an usb mode option in Rockbox. The old firmware does not start, for whatever reason. (it was rockboxed before, but when the clip+ was attached to load batteries, the original bootloader started).
TIA
  • Squeller
Got it. I want MSC mode and the only way to boot into original firmware is pressing "|<<" while turning the device on.
  • probedb
It's all in the manual on the rockbox website
  • saratoga
FWIW, newer rockbox builds have USB support, so rebooting should be unnecessary after you update.
