Topic: foo_bandintown.dll (Read 4983 times) previous topic - next topic
  • grimes
  • Developer
foo_bandintown.dll
Bandsintown
Is the band you are listening on Tour?
(uses bandsintown.com api)
actual version: 0.2
Mainmenu command:
Menu | Help | Bandsintown
Example:
[ Specified attachment is not available ] [ Specified attachment is not available ]
  • Last Edit: 26 March, 2012, 07:36:21 AM by grimes
  • delusion
foo_bandintown.dll
looks very interesting!
would be more useful, if the data is shown in an extra panel instead of the console.
if bringing this in a nice format, i'd love to test v0.2
keep on your great work!
  • mudlord
  • Developer (Donating)
foo_bandintown.dll
Could be done with a XML parser.
There is plenty around thats BSD licensed, so that it works with your component.
  • grimes
  • Developer
foo_bandintown.dll
Bandsintown v0.2
ADD: xml data now in popup window
Download: see first post
not planned, but if someone want to implement this, source is available and without restrictions.
  • Last Edit: 26 March, 2012, 07:07:31 AM by grimes
  • mudlord
foo_bandintown.dll
Cool, thanks.
Reading the API now.
  • marc2003
  • Developer
foo_bandintown.dll
i had a quick go at knocking something up in WSH panel mod using the JSON feeds. it still needs more work such as adding clickable links but it's already easier on the eye than trying to read an XML feed.
screenshot: http://dl.dropbox.com/u/22801321/bandsintown%20wip.png
  • grimes
  • Developer
foo_bandintown.dll
Some times ago i made also a bandsintown-WSH Panel:
http://foobar-users.de/index.php?topic=200...g17454#msg17454
lacks a little bit on usability, but i think the idea with coordinates on world map is good...
reading data from xml in jscript was easy, in contrast xml parser (ie xerces) in c++ is simply horrible.
  • mudlord
foo_bandintown.dll
I'm sure there are better XML parsers around. You could also code a standalone app in .NET and use foo_run?
