Topic: EAC errors in ripping (Read 1879 times) previous topic - next topic
  • h2de5
Hi.
I was ripping a CD (using EAC with LAME) and I got an error alert - SEE BELOW for status report.
Now, I listed to the suspicious positions and they seemed fine to me.
ALSO, While it was ripping it said "sync error"
What does this mean? Should I be looking for another CD source to rip in order to replace this file, due to the errors EAC found?
Any help is appreciated
Range status and errors
Selected range
Suspicious position 1:01:58
Suspicious position 1:02:04
Peak level 100.0 %
Extraction speed 25.1 X
Range quality 99.9 %
Copy CRC 632FD046
Copy finished
There were errors
End of status report
  • Last Edit: 05 February, 2012, 08:58:11 AM by db1989
  • Ouroboros
Use Foobar or CUETools to check your rip against Accuraterip.
If it fails then clean the CD and rerip, if it still fails use a different CD drive. If it still fails then you'll need another copy.
  • Last Edit: 05 February, 2012, 08:53:12 AM by Ouroboros
  • mjb2006
You have many options.
If you don't want to use an external tool to check your existing rip against AccurateRip, you can configure EAC to use AccurateRip and then do another rip. It will check your rips for matches in the database automatically. You may first have to insert a few common CDs to get it going.
You can also try different rip methods. EAC offers several (burst, fast, secure). Which one were you using? You didn't post your whole log.
If you are using burst mode, try Test & Copy instead of just Copy, and if the Test CRC matches the Copy CRC, then it's likely (not guaranteed, but likely) that the samples at the suspicious positions are actually OK.
Alternatively, if you don't need the rip to be perfect, and you can't hear any problems at the suspicious positions, then don't worry about it
